Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
Brother 845cw printer is offline -
My brother 845cw mysteriously went from online to offline, and now i cannot use it to print anything
  • 2 more comments
  • maxperform Jun 05, 2008
    I'm having the same issue. Any help?
  • Anonymous Oct 01, 2008
    Printer goes offline, need help
  • TelusPig Jan 16, 2009
    Me too!! Arghhh
  • mecit Jan 19, 2009
    Same problem here: checked all the settings and no luck. It looks like it is connected to the WLAN, but no computer can find it and print anything.
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Posted on Feb 07, 2009
If Using Windows 7 (Vista as well perhaps) and wireless connectivity is used, add a new TCP/IP port then ensure the printer is connected via that port, rather that that installed by the printer setup program. However, unless you have set a static IP address on the printer, you will have to use its Node Name (Menu | LAN | WLAN | TCP/IP Settings | Node Name) to identify it in the port configuration dialog.
Posted on Jan 17, 2010
To change print status "offline" to "online
Go to devices and printers to see if your printer is set to default. Make sure the printer cables are plugged in tight. Offline means it is not getting a signal . In Case You Still Having Problem Then Follow Us For On : Brother Printer Support
Aug 01, 2011 | Brother Office Equipment & Supplies
Printer screen reads unable to print 50on my MFC-845CW
I would reinstall the driver and see if that first fixes the problem. be sure to restart the printer and the computer after installing the driver.
You can find the driver from here:
http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=MFC845CW
Jul 15, 2011 | Brother MFC-845CW multi-function...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
I cant print any documents my brother MFC-255CW says offline and i cant get it to work
I had the same problem, and couldn't find a solution anywhere. My laptop said the wifi Brother MFC-255CW printer was offline, when the printer was definitely online and connected.
In the end I simply went into Control Panel / Printers, selected the Brother printer, and deleted it off the network. Then I chose "Add a Printer" from the network, and reselected the only printer on my home network - which was the Brother MFC-255CW that I had just deleted. The computer reinstalled the driver, and everything was fine again - haven't had a problem since.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have MFC-845CW and i cannot get it to print anything. It just stop printing. The copy works still
you umay lost your conection need to reinstall your driver also check your printer cable or try a difrent one
Jul 07, 2009 | Brother Office Equipment & Supplies
Printer message says it is offline
Hi
Kindly check the usb cable if its fine then try going into control panel open printer and faxes option & set your printer as default .
Thanks
Jan 03, 2009 | Brother HL 2140 Laser Printer
Error messages
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Dec 29, 2007 | Brother MFC-845CW multi-function...
MFC 845CW Not Printing Via Wifi
have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc845cw_us&Cat=8
Dec 28, 2007 | Brother MFC-845CW multi-function...
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
910 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
