I have a specific output channel on my Roland TD-20 sound module that is not sending any signal.
Is the volume down on the assigned instrument?
Posted on Mar 01, 2008
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
When I insert a Compact Flash card into my TD-20, the green light above the CF slot blinks and the rest of the brain freezes up until I take it out. When I insert the card prior to power-up, I get a blank...
The card MAY be the wrong format for the unit. Also the maximum size for a CF card in this unit is 4Gb. Check that yours is not bigger than that. There has been SOME compatibility problems of flash drives... try a different brand.
Jul 16, 2011 | Roland TDW-20 EXpansion for TD-20 Drum...
Roland U-20 no sound
you need to check your midi connection into the unit, check the cable and the channel that you are sending.
Dec 17, 2009 | Music
The headphones output on my roland td- 10 is sending sound just to a single channel ,I test it with diferent headphones ,same thing.
The owners manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811143/TD-10_eG.pdf Try initializing the TD-10. Check page 137. Check page 132 and 133. If the problem is still there, you likely have a jack problem. There might be a bad solder joint where the jack is mounted to the circuit board. If the warranty is up you can do it yourself if you are confident. Otherwise take the module in to have it serviced. Check here to contact Roland:http://www.roland.com/index.html
Aug 31, 2009 | Music
Computers & Internet Logo
Alun Cox
David Payne
David Payne
