Back door makes terrible (loud) squeaking noise when opening or closing - how to fix???
When you open your door you will see a flat bar that slides into the door while opening and closing. It is located between the two door hinges. There is a rubber on the door where the flat bar slides in and out, remove that rubber and you will see little rollers in the door, those rollers need to be oiled, preferably with engine oil. Oil the rollers and work the doors back and forth, the noise should abate.
Try WD40 at the hinge points or if you can try to buy a product called Tri-flow as it is better.... If you change your oil at a quick stop they should do this as a service as it is a lube check..... I still remember gas station attendants washing you windscreen!
