Question about Nikon Coolpix 2100 Digital Camera
Physically broken power switch
The power switch "ring" around the shutter button is physically broken. I was using it outdoors, ice fishing = cold. It has popped off, allowing the shutter button to hang (like a dislodged eyeball!) from its tiny power cord. The camera will still turn on and off and take pictures, download, etc. so long as you hold the switch/button together while you use it. Everything is so small that its hard to tell, but it looks like a tiny plastic ear or pin (or two or three) snapped off under the ring, where it attaches to whatever it drives beneath it.
Main Questions; Can a guy who works on cars for a living and ties flies get the parts and fix it himself? If not, any idea if its worth paying for a repair? I dont really want to open this rig up until I have some idea if its do-able...
Any thoughts would be appreciated.
    Brigadier General:
  • 3,006 Answers
The spares are not available and a repair is uneconomical as you can buy a perfect example with all accessories for an average of around £15 (US$24.50, Euro 17.50) on EBay. The 3MP 3100 goes for an average of around £20 (US$32.66, Euro 23.35).
Or get them for free on Yahoo FreeCycle. Often free ones have a broken battery chamber latch, but a small file, a carefully bent paperclip and epoxy resin glue soon make a neat replacement for the flimsy plastic tag.
Posted on Jul 04, 2009
The power button is broken how to turn ontv
Hello Andrew
You didn't specify what you mean by "Broken"
Do you mean physically broken or
It just doesn't turn the tv on?
There are separate answers for each.
1:To fix a physically broken switch you could simply open the TV up and attach 2 wires to where the switch contacts are soldered to the PCB.
Run the wires to a new switch. Probably a NO (Normally Open) type. A Round switch could be mounted easily with a drill hole through an unused area of the case. Pressing a NO switch closes the contacts momentarily to trigger the digital turn On.
2:You could remove the old switch & attempt to get an actual replacement or a similar mountable switch from a components supplier.
3:If the switch is actually physically OK and the internal contacts are working (test with multimeter) then the problem is with the digital switch mode power supply that supplies power to the main circuits.
This would probably be caused by leaky Electrolytic Capacitors on the power supply PCB.
In that case, if your up to using a soldering iron and locating the Cap's then this would be an inexpensive way to fix the TV.
Good Luck
Switched mode power supply
Capacitor Replacement Tutorial
How to Replace an Electrolytic Capacitor
Apr 05, 2016 | Televison & Video
How to fix a broken power button
Usually the button visible outside the case isn't physically connected to the actual switch, but actuates the switch positioned behind it. Try pushing something non-conductive into the hole where the button was.
If that doesn't power up the computer you'll need to go to the next step.
Sep 06, 2014 | Computers & Internet
Power button
The switch is available from wiisingonline but it is going to test even me to replace it. The switch is not supported physically which is a design fault from Acer. If you replace it it will needsome hot melt glue behind it to support it. Good luck If acerdo warranty it will only fail again when it is out of warranty
Feb 13, 2013 | Acer Iconia Tab A501-10s16u Xe.h72pn.002...
My lenovo enter button does not working please suggest me
If it's physically broken, in some cases, you can push it back into its place. If it's NOT broken and can still (physically) be pressed & released like it normally does, then problem is internal. Either way the entire keyboard module will have to be replaced.
You can contact Lenovo for a warranty replacement if it's still in warranty. If it's out of warranty, you can purchase a replacement keyboard module (usually around US$30); It can be purchased from their spare parts website but if you do not know the part number, call tech support & provide them your computer's Serial or Machine Type numbers and they can locate spare parts and prices for you.
Aug 14, 2011 | Computers & Internet
My mouse pad on my lap top isnt working, it moves around but when i click it wont select or click or i dunno what to call it lol, **** the right click works, just not the left.
Sounds like the track pad button is broken. Unfortunately that would mean it needs physically replaced. I might suggest using a USB mouse instead.
Mar 23, 2011 | Computers & Internet
How can i fix a broken power outlet in a 2006 nissan maxima? it's the one closet to the gear shift....SIGH
Is it physically broken or just no power? If no power look for burned out fuse in fuse box. If it's physically broken they screw apart. Holding front stationary, pull 2 wires off back and spin rear side of receptacle counter clockwise. To install, procedure is reversed.
Mar 01, 2011 | 2006 Nissan Maxima
I have a older model # 30 jiffy ice auger and i can not seem to keep it running consistanly. I was wandering what the carburator adjustments are. The low idle screw and the high idle screw where do I start...
Hello Randy. I can talk you through making adjustments to your Jiffy ice auger engine.
1. Read through the whole list before you start adjusting.
2. Close both jets GENTLY
3. Open the Low speed 1/4 turn
4. Open high speed jet 1 1/4 turn
5. Start engine.
6. Adjust low speed until idling smoothly.
7. Open her up wide open.
8. Adjust High speed until engine transitions smoothly from idle to high speed without bogging.
9. Shut engine off. Let it cool.
10. Once engine is cold. Fire it up and let it idle for 30 secs. Open it up wide open again. Adjust if necassary.
NOTE 1: The trick with the Jiffy's is to tune them during cold (ice fishing) weather.
NOTE 2: Low speed screw,the one on the left.
NOTE 3: High speed on the right.
Good luck ice fishing! Regards, Joe
Dec 31, 2009 | Sport & Outdoor - Others
Panasonic Lumix DMC5 record/review button
j ai une camera lumix panasonic dmc zs5 j ai prit des photo sur mode bloc notes je ne peut pas les tranferes dans mon ordinateur comment faire merci
Oct 23, 2008 | Panasonic Lumix DMC-LC5 Digital Camera
Broken power switch/ring
yes, it probably won't work, buy a broken camera off ebay for $5 and replace the whole button, it's very easy, also coolpix 2100 will be cheaper and it uses the same part
Aug 20, 2007 | Nikon COOLPIX Cameras
Nikon Coolpix 2100 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
