Question about Sewing Machines
Serger Machine My serger machine is running with a kind of hammering noise. I am suspecting that its timing is out. How can I fix that?
  • 3 more comments
  • Hoya Mar 04, 2008
    I could not wait any longer. I sent it out to a shop for repair.
  • fuzzleguz Jul 30, 2008
    I have the same problem, but I know that the upper and lower loopers are touching, and the needle is hitting the lower looper. It is not forming a stitch even though rethreading, etc. Is this my timing? Can I fix this if I am mechanically minded? I'm a poor person.
  • summer dawn
    summer dawn Apr 07, 2009
    I am having the same issue. I unthreaded the machine and have inspected where the problem is. The left needle comes down and I hear metal touching metal and see that the needle is in fact hitting the lower looper. I have a 4 thread shark europro machine and it is about 4 months old and I have sewn several things but, recently broke the needle I have the manual and I have repeated the instructions for replacing the needles over and over and I just need information on the adjustment to fix this issue? Any information is appreciated!
  • summer dawn
    I am having the same issue. I have unthreaded the machine and have inspected where the problem is. The left needle comes down and I hear metal touching metal and see that the left needle is in fact hitting the lower looper. I have a 4 thread shark euro-pro serger (model 101-548) and it is about 4 months old and I have sewn several things but, recently broke the needle...I have the manual and I have repeated the instructions for replacing the needles over and over and I just need information on the adjustment to fix this issue? Any information is appreciated!
  • caflispart Apr 08, 2009
    I have a New Home serger that the timing is out. The hand wheel comes to a point where is will hardly move.
  • Sewing Machines Master
  • 1,388 Answers
If the timing is "out", you will not be able to form the chain stitch.......do a sample to see that you have all 4 or 3 threads involved in forming a complete stitch.........if you do, then it is not timing.
I suspect there is a likely collision of parts, there are several possible contenders, tolerances for most are very small, 0 - 0.2mm, so a very good light and magnifying glass are useful, as is good hearing for when the click or clunk happens....
While slowly moving the handwheel manually, rocking back and forth and/or full rotation.....remove all threads for this..., carefully observe:
> the two loopers should almost touch as they pass each other
> lower looper should almost touch the needle/s as it passes
> is lower looper needle guard colliding with either needle/s or upper looper
> are feed dogs colliding with needleplate
> are knife blades burred, check for smooth surface/s
> are loopers burred (gently run finger along looper up to & over the point, on all 4 surfaces they should be smooth & free of "lumps")
there may also be a load of lint inside the base.......if you open this, be ready with vacuum and do it over newspaper with machine on its back.......use a small brush to assist.
also,
are your needles new and sharp
if you have sewn through pins, things can go out of balance, or get jammed inside.
Does the handwheel feel free all the way around, or is there a "tight" spot......where is everything (relative position of loopers, needle/s) when this happens, is anything obviously holding back the movement, or clicking as it passes....is it in the same place at each rotation ?
Once you have a better idea of the specific area/s of concern, post back with lots of detail and maybe a photo, and we shall have another go at specific resolution........at this stage, there are too many variables to say straight off what it is causing the noise.
Happy hunting......
Posted on Feb 29, 2008
I have a brand new brother's serger 1034D.. Its new.. as in never been used but once but it's not in warranty. It's making a grinding noise. I've liked it and is clean. Any ideas what's wrong??
Could be that since it has set for years without use or maintenance, the old oil has dried out and the motor is straining to run the machine without sufficient lubrication. Trying to run the machine in its present condition could damage the motor. Your machine very likely just needs a thorough oiling (1-2 drops of fresh good quality serger oil) every place that metal rubs on metal. (Sergers usually take a lighter-weight clear oil--different from what sewing machines would use.) You should probably throw out the oil that came with the machine. It is probably old and should not be used in your machine.
A serger requires much more frequent oiling (the moving parts behind the front door, ie the looper mechanics, etc.) than a sewing machine. In addition, about every year I take the bottom off my serger and lube the moving metal parts inside with Tri-Flow Synthetic Lube. It has a whole different sound after getting some TLC!
To keep your serger operating for years, be sure to regularly clean and apply a couple drops of lube as recommended in the owner's manual (maintenance section).
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj1woi47IzQAhUCwmMKHVVPCBQQFggtMAA&url=https%3A%2F%2Fwww.brother-usa.com%2FModelDocuments%2FConsumer%2FUsers%2520Manual%2FUM_PL_2100_EN_238.PDF&usg=AFQjCNF99J5PVNoFcHjv5FJcR-6eyNqTNg&cad=rja
Nov 03, 2016 | Sewing Machines
Serger Machine
HI,
Jun 28, 2008 | Sewing Machines
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
Does the Singer Serger Ultralock 14u52a use standard needles or do I have to get special ones?
Serger needles are different from regular sewing machine needles, but like sewing machine needles, they are generic. That means that if you buy a serger needle, it should fit most sergers from any manufacturer.
My favorite manufacturer is Organ; they've been in business for a long time and manufacture for commercial and home machines and sergers and they're quite inexpensive.
Jun 23, 2014 | Singer Sewing Machines
How can I fix a jammed, squeaky hand wheel?
This sounds like a bushing in your serger or the upper looper shaft heats up with use. This the swells the metal and seizes the machine. This is always hard to fix right because there are many points on the serger that need regular lube and can heat up. it is an eliminate 1 joint at a time and try agein
May 28, 2014 | Husqvarna Huskylock Computerized 910
I've got a serger by Brother and I got fabric
the serger probably needs to be checked at a sewing machine shop
to see if the machine is out of time & to make sure the loopers
aren't damaged
Jun 07, 2012 | Brother Sewing Machines
Singer Tiny Serger: Motor runs but machine
pull the 4 bottom rubber feet out and remove screws hidden in holes. Lift main body of serger up. you will see the gears. Probably drive gear on motor shaft got hot and slid on motor shaft.
Dec 10, 2009 | Singer Tiny Serger TS380
Retiming Mylock Serger 234D
Ooh, I've heard it is difficult timing a serger because there's more involved than a sewing machine.
You can try looking at videos and web sites:
serger timing Google Search
Nov 16, 2017 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
373 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
