I have a jensen nav 101 navigation, I use it with a jensen vm9022 in my car. Whenever I use the navigation, the audio will cut off the music and act like it's gonna give me directions, but there will be no words coming out. I called in and I was advised to update my sd card with the disc, but that isn't working. Just wanna know if there are any special steps or instructions that I have to follow in order to load the sd card
  • KEITH E. BROWNE Oct 26, 2008
    I have the same problem, but I am using the 9512 head unit.
  • Anonymous Mar 10, 2009
    Link does not work. Through Jensen, there is a map update now. Trying to get it into my SD card now...
You can get new software and maps for this now
Go here https://tmp.horizonnav.com/shop.php
It will give you what you really need
Posted on Jan 30, 2009
I have the same system and there's no problem with the sound.
First, the SDcard with the navigation software should be in the NAV101 not on the VM9022.
If you want to listen music in the same time you have direction from the navigation, you should select your radio station, or sdcard music. After that, you enter in the navigation by the PIP button. If you use the SRC button, you'll stop the music and only hear the NAV direction.
When the NAV101 want to give you an information, the music sound turn off, the direction is given and the music came back.
Be sure to put the NAV101 in English.
Be sure the P.VOL for the NAV is ON in the VM9022 menu (P.19 of VM user manual)
Be sure the cable between the NAV and the VM is correctly installed
Posted on Jun 20, 2008
FYM
Posted on Apr 26, 2008
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
Can you use nav101 on a jensen phase linear or do you have to use a nav102
nav 101 is applicable to any of the Jensen line of DVD media centers...
Nav 102 is just an updated version.
Oct 06, 2010 | Jensen Car Audio & Video
Jensen car stereo VM9022 has a password Need to bypass it
call Jensen at 1800-323-4815 they will give you the code
Mar 14, 2010 | Jensen Car Audio & Video
On the jensen vm9022 how do you reverse the subwoofer polarity
CLICK HERE for a copy of your manual in PDF format.
Phase control is featured on page 17 (21 of pdf)
In the Audio Sub-Menu:
Subwoofer Phase Adjustment: Touch the sub.w icon to
access the subwoofer polarity controls and reverse the
subwoofer signal polarity from to 180°. Reversing
polarity can improve bass response related to speaker
configuration.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 06, 2009 | Jensen Car Audio & Video
Looking for upgrades for jensen nav 101
Please go to www.horizonnav.com and then E-shop
look up Jensen and buy a new maps and software upgrade.
Gate5 stop supporting the unit and Jensen went to HORIZON NAVIGATION for help.
They stepped up and now off us new maps and software that work better and is much easyer.
it is way faster than GATE5
Jan 24, 2009 | Audiovox NAV101 Car GPS Receiver
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio & Video
Jensen vm9412 car stereo
when this happens , the only thing to do is, send it back to the factory , and have the warranty ready with your book that came with it , there is a 1800-no. to call to send to the company,cause like a computer, that needs the program to work right, now it need to be reinstalled,i recomend never installing the navigation dic on here, it causes probs , and i learned it the hard way...the only way to get it fix is by retruning it to the company with your warranty. oh and if you don't have it this there no.-18003234815 for repair, they will let you know how much to fix and where to send it..good luck.
Aug 28, 2008 | Jensen VM9410 Car DVD Player
Jensen vm9022
was the unit new or was it a demo? if it was new in a box I would take it back to where you purchased it from and exchange it. some decks the code can be reset such as the case you bought a used car ect., and others you need to replace the code IC in either case you will need to contact jensen custmer service or get the technical schmatic.
good luck stereo tech
Jan 27, 2008 | Car Audio & Video
903 people viewed this question
 Grubhead
Grubhead
