Question about SanDisk Sansa e260 MP3 Player
The battery on my player is completely dead
Whenever I try to recharge the battery through my computer, I receive a message that states "a usb device has exceeded the power limits of its hub port."
What should I do?
  • 34 Answers
Try using a different port on your computer If it is a desktop try the ones in the back of your computer.
Posted on Feb 29, 2008
Won't turn on unless on computer
The battery inside the player is not taking or holding a charge.
While it gets power through the USB port, it works, but the battery is not getting recharged.
Feb 19, 2014 | Ematic Em174vid 1,5" Color Display 4gb...
Can't turn on my mp3 player. I have tried to hold the volume buttom but it does not turn on at all.
what type of mp3 player ?
Charge your MP3 player.
The battery might just be dead, in which case letting it charge for a few hours corrects the problem.
Plug the USB data cable into the USB port on the MP3 player and insert the other end into one of the USB ports on your computer.
In a moment, the computer states that it has detected the removable device.
Sometimes the MP3 player needs to update itself, and it can only do so while connected to a computer.
When the MP3 player detects the computer, it attempts to connect to the Internet and retrieve any system updates available for the device.
Replace the battery.
The battery is usually the first part of the MP3 player to go (especially after excessive use). Although you can manually change the battery on most MP3 players, you need to send your
Apple products (iPod, iPod Nano, iPod Touch, iPhone) into the company so they can change the battery for you.
Purchase a new MP3 player.
If your MP3 player has received any sort ofwater damage, it is not going to turn on at all and there is nothing you can do to fix the issue.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
My MP3 is dead. I have attached it to my computer which should recharge it, but that this not working. Suggestions?
Have you tried a different cable?
Does the USB port on your computer power other USB devices?
The manual says to plug it into USB, make sure your computer is switched on and leave it for at least 3 hours. No other requirements.
Try leaving it on charge overnight. Has it been left umcharged for a while?
One final thought that has caught me out. Are the plugs pushed fully in?
A dead battery is a possibility, how long have you had it, and has the pattery lasting the full expected time?
Jan 29, 2011 | Thomson H106 MP3 Player
MESSAGE STATES THAT BATTERY IS LOW, AND KEEPS SHUTTING OFF. BATTERY SHOWN ON SCREEN AS DEAD.
plug it in to your computer via the usb cable for a few hours, the car and home chargers are not recommended for the initial charge as there only a trickle charge...if it still hasn't charged up using the usb cable, there is probably a problem with the usb port(charging port)
let me know how you make out after charging it via the usb cable that was supplied with the unit.
bill
Aug 20, 2010 | Tomtom ONE GPS Receiver
Did not receive manual. How do you recharge
Simply attach the USB plug that came with the device to your MP3 Player, then plug the other end into a computer, it should automatically start charging! A full charge usually takes about 2 hours.
Hope this helps!
Dec 25, 2009 | SanDisk Sansa e250 MP3 Player
Blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
Dec 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cannot recharge battery on my explorist 400 gps
I had the same problem with mine, the AC adapter fails really quickly. Try to go to Radio Shack and get the 3-12v switch able AC adapter that is 1 amp, and select the 4.5 volt setting. This setting is a whole .5 volts less than the one that comes with GPS, but its the Amps that matters. Make sure you get the correct plug with the adapter, I got the "B" plug and follow the directions that came with the adapter to match the right polarity, or you will fry your GPS. Also, the computer just supplies enough power to run the GPS, but not to charge it as long as you have the USB 2.0 ports.
Jan 24, 2009 | Magellan eXplorist 400 GPS Receiver
Usb recharging does not work
I have seen this many times. Your battery is most likely depleted to the point that it is incapable of sending a signal to the computer. You will more than likely need to have you battery replaced. You can jump start your iPod with a wall charger, but you lost yours. A simple charger can be bought off of eBay for less than ten dollars. If you get a wall charger and nothing happens, your iPod is dead but it sounds like a battery issue.
Aug 28, 2008 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
