Question about Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
Roadmate 700/760 freezing after selecting address or recent locations, doesn't seem to effect the map screen if no route is selected.
  • Bobmci Feb 29, 2008
    Yes, I did all the media tests, no errors, reset the GPS and User data. I even reloaded the V.5 MAP software incase a file got corrupted. Still locks on Calulating or Map routed screen. The Magellan technical group is a joke. They don't listen, ask the same thing over and over, and basicly just want to sale you another unit. They're probably really a sales group. They "offered" the trade deal but I'm going to look around before doing the trade in, may find a better deal at Fry's or Costco.
My Magellan roadmate 760 shows the map of my home and will not display the new destination on the screen. Although when I press the view button the directions are displayed in the text form and the voice that has talked as I am setting up does not give me the directions that are on text. How do I get the unit to remove my home map?
Posted on Aug 25, 2008
  • 50 Answers
I use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Posted on Feb 29, 2008
SOURCE:
How do I delete address from recent locations
Hi Gloria,
To delete a Map, please go to: Settings> Select Map >To select a map to use, tap map selection and tap OK > To permanently delete a map from your TN20/TN30, tap Delete
Hope this helps.
Regards,
Gaby
Motorola Mobility
Oct 03, 2014 | Motorola Mobility MOTONAV TN20 Portable...
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Garmin Nuvi 300 - SD problem
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Jul 26, 2008 | Garmin Nuvi 660 GPS Receiver
Magellan RoadMate700
I think Magellan makes it so if you don't update your map every year it will freeze up. Mine does the same thing and they told me to buy an update for $99 last year so I did and it worked and then after it started telling me my map was over a year old this year it started freezing up again. I don't want to pay $99 every year to keep this thing working. I wonder if Garman or Tomtom does the same thing.
May 31, 2008 | Magellan RoadMate 700 GPS Receiver
No maps found!!
Hi - I have the same model GPS but I've been unable to locate a copy of the CDs and I'd love to get a copy of them - would that be possible? My email address is [email protected]
As far as re-installing he maps, here's what I've found. I think this might help:
Locate the files that are loaded on the computer.Magellan Roadmate Manager example: C:\Program Files\Magellan\Magellan RoadMate Manager NA\Map\Basemaps
Copy all files. Make sure your Roadmate is connected and click on Example E:/Removable Disk and paste them with other files. It takes a few seconds to 1 minute to transfer the 25.5 mb file so don't unplug it until it is finished.
Sep 29, 2007 | Magellan RoadMate 300 GPS Receiver
How to hard reset magellan 700
Hussam.. I believe the newest software upgrade you can get for the 700 is version 4.32 which is the same version used on the 760's. The maps are stored on the hard drive, so I do not think a reset will help but here is how it's done. 1. At the user select menu (first screen to appear after initial turn on) hold down the zoom out key (-) and the repeat button (on top of your unit). 2. Once at the "secret" menu, select reset user data. This will reset all of your personal information from the unit. All of your POI's will be deleted as well as your user name (which you can re-create of course) 3. Your unit will re-boot automatically and that's how you reset your unit. Like I said though, I do not think this will revive your maps. If you have the maps on a DVD-CD then you can reload them that way, otherwise send it to the Fort Worth, Tx repair center and they have the proper program to load data directly to the hard drive. Good luck! -Daniel
Jun 28, 2007 | Magellan RoadMate 700 GPS Receiver
Cant route to addresses in certain cities
Perhaps it is just a matter of old maps. According to the Magellan web pages, new maps will be available for download and update in August 2007.
Jun 21, 2007 | Magellan RoadMate 6000T Bluetooth GPS...
Magellan Roadmate 700 freezes up
Try resetting user data. At user menu, press "-" zoom out and repeat button at same time. select reset user data, it will reboot automatically, then check to see if it is any better. If not, hopefully the software came with your unit and you can re-install it. Good luck and let me know if you need help with the installation. Daniel
Mar 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
354 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
