Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell electronic thermostat malfunction for oil heat zone
We have a Honeywell electronic thermostat, in fact 3 in our home as we have 3 heating (oil) zones with forced hot water. They have all worked fine until tonight. One of the thermostats is consistently resetting to 75 degrees regardless of us "holding" it or programming it for a lower setting. Any ideas?
  • 30 Answers
Try changing the batteries.
Posted on Mar 04, 2008
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Dec 26, 2009 | Honeywell Electronic Programmable...
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
Need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Oct 18, 2009 | Honeywell Electronic Programmable...
Short burn cycles
if thats a new themostst it sounds like you didnt set the cycle dip switches correctly,the type of heat you have is unknown to the thermostat so you have to tell it or it may short cycle or overheat
May 02, 2009 | Honeywell Heating & Cooling
Heating & Cooling Logo
457 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
