Question about Polaroid PDM-0824 Portable DVD Player
PDM-0822BD After watchng CD for 10 min. there is a background sound which is there with playing many CD's. It always starts after 10 min.of play, continues to the finish of each CD. ?????????
    Problem Solver:
  • 22 Answers
This is called "audio transfer saturation. Rarely happens but will when there is constant use of player. Drain saturation by removing battery (if attached), With the power adapter still attached, turn off player and unplug adapter from wall for several hours. Saturation should discharge back through you adapter. Disconnect adapter from player before plugging back into wall.You may have to do this periodically when constant music is played.
Posted on Dec 29, 2008
Right rear hinge for dvd door has broken and dvd will not play. can this be fixed?
Yes it can. You will have to order the whole lid assembly. The DVD will not play untill you get a new lid bcause when its engages a switch.
Aug 19, 2010 | Polaroid Portable DVD Player PDM-0822BD
I get the message "bad disc" with every disc I put in the player.
ok best bet is that your laser (what reads the discs) in your laptop is dirty, use a cd/dvd cleaning disc to clean the laser, can buy them from most computing, music shops
Jun 29, 2009 | Polaroid Portable DVD Player PDM-0822BD
PS3 freezes but sound still works
when it happens, give it some time, like 5-10 min. the ps3 is most likely accessing the hard drive, and if it is, shutting down in the middle of it could currupt your hdd. if it doesnt work, even after 10 min, call sony tech support, but if it works fine afterwords, i dont see why it would be neccessary. unless it gets worse, i think you should just turn it on, turn it off after a few min, then back on, and then play.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
I think the problem it's graphic card
Check your antivirus software. This seems to be the problem of something running in the background when you are playing the game. If it would have been the Graphics card, the game would not have worked, or would have given errors.
Try to disable your antivirus or any other program that may be running in the background. Then check once again.
May 14, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Dvd player movie never loads
The lens on the DVD player might be dirty. Try taking a q-tip and soak it in rubbing alcohol. Next, open the cover and look for the laser lens. This is usually a clear white plastic circle looking piece. Take the q-tip and  clean the top of the laser lens but don't rub to hard. Let it dry for 10 minutes and see if the DVD will play. If not, then your DVD player is broken and needs to be serviced.
May 02, 2009 | Polaroid Portable DVD Player PDM-0822BD
After 10 min. of play time the dvd stops working
This is most likely a problem with the power supply to the drive motor. A component is breaking down and the supply voltage is dropping below operational levels after warming up.This is a problem that needs service in a service center or someone who is a experienced electronic technician to take apart the unit and test it for bad components.Hope this help you with your problems.
Mar 18, 2009 | Polaroid PDM-0742 Portable DVD Player
Dvd plays upside down how to play normaly
To rotate the DVD screen display, hold down the MODE button or DISPLAY MODE button (depends on model) while a DVD is playing to turn the picture right-side up.
Mar 27, 2008 | Polaroid Portable DVD Player PDM-0822BD
Brightness hidden
Press and hold the MODE button for a couple of seconds, Use the arrow keys to adjust. You can view the manual here.
http://www.polaroid.com/service/userguides/ce/portable_dvds/pdm0822bd_ugl.pdf
Feb 14, 2008 | Polaroid Portable DVD Player PDM-0822BD
NEED REPAIRS ON DVD PLAYER
polaroid dvd pdm-0722 it playes but no picture if you push the button near the screen it will come on for a second but the picture is also upside down can you help thanks this player is not used that much no kids thanks
e-mail is corv1990@eatel.net
Sep 02, 2007 | Polaroid PDM-0824 Portable DVD Player
Polaroid PDM-0824 Portable DVD Player Logo
88 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
