-   I have the same problem, mine did not come with software just a small disk to take me to the music store. It used to work on my computer but now it does nothing.-   mma06c
Mar 03, 2008
-   when i plug in my mp3, it says writing, but nothing happens.-   Guest
Mar 01, 2008
-   My sansa clip used to be recognized on my computer but now it does not show up when I plug it in. I put it in a friends computer and it works fine. I do not have the disk and can not find a place to download a driver. Please help, i need my tunes.-   missinhippy
Heres something that worked for me....when I first got my e280 it worked fine then one day it just stopped.. After dealing with sansa customer support several times without any luck and trying everything else I could find in various forums, I came up with something that works for me....1st, if you are running vista, the device has to be turned of when you plug it in. If that does'nt work, try putting your sansa in lock mode...with it turned off plug it in to your pc and hit the power button until it turns off the push it again until it comes back on I did this several times and It worked and it continues to work....Good Luck.
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa Clip MP3 Player
it won't charge, it will say it is then stop and I have to put in back in again 5 times and did...
(More)
it won't charge, it will say it is then stop and I have to put in back in again 5 times and did doesn't go all the way up because if I try, it loses a charge
