Question about Sony MDR-7506 Professional Headphones
Need to repair jack end of cable.
I need to resolder a connection on the jack end. Getting a new set of cans ain't in the cards...fixed incomes suck. These are the only cans that have ever suited me, and I've tried a lot of them in 20+ years. Failing a way to defeat the press fit (which is likely the case), I'm gonna need a part number and a road map. Thanks.
  • 3 Answers
You'll need an 1/8" male phono plug, also called a trs plug, a soldering iron, and solder. you can get this stuff at a place like mouser. don't buy any junk from radio shack. the soldering irons are ****, the solder is **** and often won't make a good connection, and their phono plugs are the cheapest of cheap at high prices. if you don't know how to solder already, i wouldn't recommend taking your first shot at soldering on your headphones. practice soldering some small wire first. the wire used in the sony headphones has a transparent coating of lacquer or teflon which will need to be scraped off with a knife or burned off with a lighter. remove just enough to make your solder connections and no more, maybe 1/8". the bare ends should be clean before soldering. a headphone plug has a tip, ring, and sleeve, in that order. the tip is left +, the ring is right +, and the sleeve is a common -. i don't know what color wires are in your headphones but i'm betting there's a blue, red, and a bare copper. the blue would be left, red right, and bare copper would be common. the contacts of the replacement plug in relationship to tip, ring, sleeve should become obvious with a close look. if it's not obvious, a multi meter set to continuity would help. good luck
Posted on Apr 20, 2008
Monitor is OK but when turned on the screen is black with a little square that has a message "Dell, No input signal". How can you repair this.
Monitor is not getting signal - picture from pc. Did this ever work or is this new pc? Is PC running? Does it do more than just blow fans? Like hard drive spinning up etc.. Check your video cable connections. Turn off monitor and pc first. Remove and re plug both ends of the video cable. Look for bent pins in plug ends before re pluging. Try a different cable if possible. If not fixed, you may need a new video card. Is this a pc that was working and suddenly failed? Either the pc is not running, or the video card is failed.
Nov 09, 2010 | Computers & Internet
None of the ear pieces work only if I move around the Jack plug thing
sounds like the jack is faulty tghe cable has been pulled and the wire probably stripped off connectors. if you can access a electronics or audio shop purchase a new jack these are cheap and you will need to cut the end off the cable there should be three wires an earth and a left and right cable these will need to be resoldered on the new jack plug.. make sure it is a stereo jack...!!.the best way to solder is to gently heat the cable end and dab a bit of solder on each before trying to attach to the jack. then when you come to connect the jack end lightly touch the connector and cable together with solder iron and solder..good luck A
Aug 13, 2010 | JVC Gumy Ear Bud Headphone - Peppermint...
I cannot connect the Ethernet male end into the female end
On the male end of the cable there should be a little plastic clip that sticks up, this is what holds the cable in and if you want to disconnect the cable you will have to push done on this clip to release it. These are prone to break off and if it does break off your best bet is to buy a new cable. These can be replaced but will cost about the same as new cable and are not as reliable.
moz-screenshot.pngRefer to this image to see the clip I am referring to: http://www.nuggetlab.com/comptia_files/equipment/net_CAT%205%20cable%20with%20RJ-45%20connector.jpg
Jan 13, 2010 | Dell Inspiron 5150 Notebook
The dc power plug is broken
Yes.
Is the connector on the power adapter that plugs into the laptop?
If so, this is an easy repair, purchase a new connector from electronics parts shop, cut off the old connector and solder the new one on the end of the cable. MAKE SURE YOU SOLDER THE CONNECTIONS TO GIVE THE CORRECT POLARITY ON THE CONNECTOR, OR YOU WILL DAMAGE THE LAPTOP.
If the power socket on the laptop is faulty, this repair is more difficult. The socket may only need resoldering on the motherboard or in the worst case a new socket replacement. Either way the laptop need to be dismantled to get at the power socket.
If you don't feel you can handle this, get it done by a computer repair shop or a techo friend.
May 28, 2009 | Computers & Internet
New charger but no ac power to pc
A common problem is for the power jack connections on the system board to go bad. They break loose from the main board because the power plug gets flexed and then the power doesn't get from the adapter to the board. No power light (or intermittent flickering) and no battery charging results.
What you need to do (or have done) is to resolder the power jack onto the board. This isn't difficult, but it involves getting the main board out to reach the solder side. In some cases the board can be damaged because of the bad connections and isn't repairable. Then the board needs to be replaced. But most often the soldering fixes the trouble.
Apr 08, 2009 | Dell Inspiron® 1501 (N11157) PC Notebook
No power going into power jack
You would be better off phoning small pc repair stores and getting the best price to replace it
not a good idea to fix it yourself
the cost usually runs between $60.00 - $100.00
I know people that fixed me themselves and believe me they have ended up with problems
Jan 13, 2009 | Computers & Internet
Toshiba tv makes static type sounds when I turn it on.
I would replace or at least resolder the connections on the cable jack on the tv itself. You seem to have a loose ground or cold solder joint on the ground portion of the jack. Be sure as well to check that your actual cable has a good solid end on it as well.
Jan 13, 2009 | Televison & Video
Gateway M3A laptop DC power connector problem
You have 2 choices.. One : You can Desolder the DC Power Jack from the mainboard, clean the pins and connections on the board, then Resolder the DC Power jack back on. Or TWO: purchase a new DC Power Jack and Remove old one / replace with new one.. This will fix your Laptop Power problem..
Jun 02, 2008 | Computers & Internet
Problems with hole you place the ear phone
The ear phone jack is lose and your gonna need to or have someone resolder the audio jack inside the unit. if you know how to solder then it shouldnt be a big deal once you get the bugger apart. if your not good with a soldering iron, take the unit to an electronic repair shop and there shouldnt be much of a charge exept for minumum beance charge as this is not a major repair UNLESS the jack is ripped out of the PCboard or theres a flex cable connected to the ear jack as thats hard to fix correctly. Good Luck
May 20, 2006 | Samsung YP-T8 Digital Media Player
Sony MDR-7506 Professional Headphones Logo
1,313 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
