Question about GE Profile Harmony DPGT750EC Electric Dryer
Touch screen Hello all you dryer experts,i have a ge dryer m#dpgt750ec2pl with touch screen.I plugged the dryer in and the "touch" screen lights up with the menu.I can select options on the screen itself,but,i cannot go back,because,none of the buttons on the panel will work.I cant even power the screen down because the power button wont work,or the start button,back button and even the help button.I have to unplug the appliance to restore the menu screen.Its outside of its warranty,any body want to take a shot?Thanks,jerry.
As a thought you may want to re-initiate the electronics. Don't know if this can help but it might:
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
This takes you through a processes of initializing the touch screen. I have a different problem on my Harmony dryer but I've used this to check diagnositcs.
Regards,
Robert...
Posted on Apr 07, 2008
Dryer has power, control board lights up and beeps when touched, but dryer won't start
I would check the door switch. if switch is good, then control board might not be recognizing switch as being closed. Check for proper voltage at the plug. any volts under 208 is bad.
Nov 18, 2015 | GE Profile DPSB620ECWW Electric Dryer
GE Harmony Washer and Dryer will not turn on after power surge
The control panels on both machines may have fuses that need replacing after surge or a component on the panels have blown due to surge.
Nov 13, 2013 | Whirlpool Washing Machines
Touch screen not working
i have same problem the cable to cn8 is broken on mine. maybe yours is unplugged but so you know it's $600 for servvrvice man and $ about $300 for the part so far I have NOT found a way around it BUT I am NOT done yet. Joe Comer. You can contact me directly ayt joecomer39@gmail.com
Mar 20, 2013 | GE Profile Harmony DPGT750EC Electric...
GE Harmony profile DPGT750G Touch screen is blank. can you help?
first unplug the unit from power,remove the control panel so as to view the back side of the screen,then where the small ribbon cable enters the screen make sure it is tight,unplug it and re-plug it in straight and securely,if its loose put a small piece of scotch tape on the insulated side of the ribbon cable where it plugs in to tighten fit,dont put it over the copper connections though
May 04, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
How to replace the blower on a DPGT750EC2PL
The way to remove/separate the spinner from the blower motor is that, if you'll notice, there's a flat notch on the back of the blower motor shaft. You have to put a crescent wrench or some sort of adjustable wrench on the backend of that shaft to keep it from spinning. Now, the other thing that you may not be aware of is that in order to remove the nut for the spinner/blower cage, you have to turn the wrong way. Yes, you heard me right, the opposite direction. I know we were taught, righty tighty, lefty loosey. Not in this case, the nut is removed in the opposite direction.
Apr 08, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Problem with "model selection connection" message on touch screen
GE Dryer - Profile Harmony
DPTGT750GC1WW and perhaps others.
If a screen comes up with "model selection connection". It could be the motherboard that has problems. Most likely not the touch screen.
Possible solution - Before calling for repair.
- First unplug the dryer for two minutes.
- Hand spin the dryer drum one or two turns while unplugged. ( in case motor was over heated)
- Make sure the dryer door is fully closed.
- Plug in (after the two minutes).
- Cross fingers
- Start.
- Let dryer cool between loads when possible.
If this fails you may need to call for repairs. I think GE has one year repair plan unless you bought extended plan. If you paid with credit card, see if it was a paid with a credit card that extends warranty another year. Perhaps look into this "card choice" for your next high end purchase.
Only if this helped...Donations_M.D.,box774,Fairfax,CA - Another try if this fails - If you dare - Unplug, you can remove about three screws holding top panel on (on rear) and tilt top forward. Check to see that all connectors are seating well on motherboard. (White box in center). Hope see works for you!
Parts:
WE04X10105 Display
WE04X10107 Power/PCB ASM-Main (motherboard)
WE04X10127 Power filter (circ) EMC
Aug 25, 2008 | GE DPGT750GC Gas Dryer
Need Help
Have you tried unplugging it for 3 min? That will reset the computer. If that don't work you might need a new touch screen \ computer
Jun 29, 2008 | GE Profile Harmony DPGT750EC Electric...
LCD display light went out
Replace the touch screen \ computer.
Jun 26, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
1,023 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
