Question about Dryers
Heelp I am trying to change my 3 prong cord to a 4 prong cord on my dryer and I NEED TO KNOW HOW TO CONNECTT THE WIRES TO THE TERMINAL BLOCK WHAT GOES WHERE
  • mverysmart Mar 03, 2008
    Ok i broke the wall on the terminal block. the piece between the red and white cord. But I made sure to seperate them before plugging them in and it worked, but when i went to unplug the dryer to put the door back on it popped and fizzled and now it wont work I believe the ground wire and the screw that holds on the terminal block touched. What in the hell do I do now or am I just screwed.
  • 156 Answers
Black to black red to red white to the center green to the ground with ather green wire
Posted on Feb 29, 2008
  • craig carter Mar 04, 2008
    you can order a new block for the dryer at sears.com or any local appliance store should have one and also make sure you rurn off the breakers and back on sometimes short like that will pop the breaker good luck
How do I change a 4 prong to a 3 prong dryer code
When replacing a 4 prong cord with a 3 prong cord you put black and red wires to the outside posts of your terminal block. The white wire from your three prong dryer cord goes to the center of your terminal block. The yellow and green wire from the dryer go together and attach to the cabinet ground.
Nov 22, 2014 | Dryers
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
Need to replace 4 prong cord with a 3 prong cord on a new 500 series dryer.
On the back of the dryer, remove the screw(s) that hold the access cover to the back panel that cover the terminal block where the cord goes through the back panel and connects to the wiring terminal power block, loosen the two screws on the cord clamp the clamp it to the back of the dryer just enough to release the cord, remove the four nuts / screws that are connecting the 4 wires from the cord to the terminal block and or the back of the dryer,with the new 3 wire cord just match the colors on the terminal block with the same color wires that are connected to the other side of the terminal block, red,black on the outer most terminals and the white or green to the middle terminal, IT IS IMPORTANT THAT YOU PLACE A JUMPER WIRE/STRAP FROM THE MIDDLE TERMINAL WHERE THE WHITE OR GREEN WIRE CONNECTS TO THE TERMINAL BLOCK OVER TO THE CASE/CABINET OF THE DRYER, THIS CAN CONNECT TO THE CASE AT ANY AVAILABLE SCREW NEAR THE TERMINAL BLOCK! In short this means that the neutral and ground of the dryer must be connected together in a 3 wire set-up.
GOOD LUCK!
Aug 21, 2010 | Kenmore 500 6952 Dryer
I have a 3 prong to change to a 4 prong cord on my dryer
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral ad ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 06, 2010 | Dryers
Changing electrical Cord from a 3 prong to a 4 prong. I need a wiring diagram
black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
Dec 20, 2009 | Whirlpool Dryers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
How to hook up a ge dryer change from a THREE PRONG TO FOUR PRONG HOOK UP
Replace the old Three prong cord with a 4 prong.
White wire from 4 prong cord goes to the center terminal of the connector block. If there is a metallic strip on that terminal that goes to ground remove it from the terminal and bend it away from the terminal and down so it either touches the case or ends in thin air. Be sure it can't touch either of the outside terminals of the 3 terminal block.
Red and Black wires of cord go to outside terminals of the three terminal block. It makes no difference which one goes on which terminal but I usually attach them so the color of the cord wire matches the colors of the wires already on that terminal.
The last terminal is green and should be attached tightly to any screw of the case or any metal bracket attached to the case that it is long enough to reach as this is the ground. This lead protects you from electrocution if the dryer has an internal problem and should be tight to the case.
Sep 22, 2009 | Dryers
Swapping dryers
just remember a 3 prong cord the middle wire goes to the middle on the terminal block,the other 2 does not matter there both 120 volt,same if you have a 4 prong,the white wire goes on the middle on the terminal block,the red and black go on each side and the extra green gets mounted to the cabinet,,let me know how you do-mike
Mar 23, 2009 | Kenmore Dryers
Roper Dryer
Mar 02, 2009 | Roper Dryers
Dryers Logo
55 people viewed this question
Top Dryers Experts
Marvin
Marvin
