Question about Dryers
I am trying tochange my
I am trying to change my 3 prong dryer cord to a four prong. the dryer is a kenmore model # 86980100.
  • 2 more comments
  • mverysmart Feb 29, 2008
    i need to know how to connect the wires on the terminal block i had a 3 prong cord but because of the plug at my new house I had to change to a 4 prong cord. somebody heeeeelp
  • mverysmart Mar 04, 2008
    im new and i clicked fix ya not low scores
  • mverysmart Mar 05, 2008
    Ok i broke the wall on the terminal block. the piece between the red and white cord. But I made sure to seperate them before plugging them in and it worked, but when i went to unplug the dryer to put the door back on it popped and fizzled and now it wont work I believe the ground wire and the screw that holds on the terminal block touched. What in the hell do I do now or am I just screwed
  • mverysmart Mar 06, 2008
    thats n6t a d40b q4est56n and yes 5 d5d f5x t4rn the brea2er b6x 6ff and 6n and 5t st533 5snt w6r25ng
  • 5,911 Answers
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similar with one exception. The 4-wire plug uses an additional (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope this helps you.
Posted on Feb 29, 2008
  • 2 more comments
  • Jeff Rockwell
    Jeff Rockwell Mar 03, 2008
    Thanks for Trying? You couldn't figure out how to convert your dryer plug with the instructions I gave you? I've worked on appliances for a living and have had to convert many dryers for this very reason. It would be nice to get feedback about the advice given, so that I can possibly give you better guidance instead of leaving low rating marks with no reason given.
  • Jeff Rockwell
    Jeff Rockwell Mar 04, 2008
    I appreciate the feedback. I was just wondering if there was something more that I needed to assist you with. Sometimes instructions aren't clear and those that may not understand, choose to disregard the advice rather than asking questions. I was just hoping this wasn't the case. I hope I can be of assistance again if you need it.
  • Jeff Rockwell
    Jeff Rockwell Mar 06, 2008
    This may be a dumb question, but have you checked the circuit breaker that feeds the outlet? Normally, when you accidentally ground something in the manner you described, the circuit will be the first thing to trip.
  • Jeff Rockwell
    Jeff Rockwell Mar 07, 2008
    Something went wrong in the translation with your last response, because half the characters appear as numbers. I pretty much figured out your response, though. If you've double checked the circuit breaker and the wiring is intact, AND installed correctly, you may have blown the thermal fuse. It is a small white plastic device mounted on the BLOWER FAN HOUSING. There will be two wires connected to it. This fuse acts as a circuit breaker, but cannot be reset if it trips. It has to be replaced. You need to unplug the dryer, locate the thermal fuse and disconnect the wires leading to it. Take a continuity reading across the leads. It should read 0 ohms if good. You can see a picture of it at repairclinic.com. Just type in your model number in the search menu and look at item #2986. I hope this is the source of your problem.
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
Kenmore Washer/Dryer Combo Unit Cord Issue
the extra prong is just anothere earth over here we hacve three prongs and 2 prongs its just a better earth thats all and it wontstart a fire ii always change mine i did it to my toaster,microwave,iron,and pc all over 1 yr ago nothing ever happened
Sep 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Have a kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what? Can we wire our 3 prong plug from the other dryer to the four wire dryer? And how would we wire this way...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Kenmore 400 6942 Dryer
I would like to change the electrical plug on my dryer
The outlet or the cord? You can purchase 3 or 4 prong cords at any Home improvement store. There is usually an extra screw at the terminal block for just that.
Jul 06, 2010 | Kenmore Dryers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
I need help in changing the 4 prong to a 3 prong cord
It would be a better and safer idea to change the receptacle from a three prong to a four prong. You would also be in compliance with the electrical code. That being said, here is the info you will need to go either way.
Apr 03, 2009 | Kenmore 84832 Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
I need to change the power cord on our duet dryer from a 4 prong to a 3 prong The 3 prong does not have a neutral wire does that matter?
I think you need to read the following link to make sure you aren't violating any electrical codes, first:
Yes, a 3-prong DOES have a NEUTRAL wire. That would be the WHITE terminal. A 3-prong does not have a separate ground. The NEUTRAL is usually grounded at the appliance casing by a jumper wire.
Read in the "Additional Notes" section on how to convert from a 4-prong to 3-prong. Also note that some of the newer appliances require a 4-prong plug in order to run correctly. I have a Kenmore HE3 model dryer that is currently using a 3-prong power cord. Since this model Kenmore is manufactured by Whirlpool, and is identical to the Duet, you should be okay with a 3-prong plug.
Aug 08, 2008 | Dryers
Dryers Logo
239 people viewed this question
Top Dryers Experts
