Small Gas Engine Manual
I am in a small gas engines class at my highschool... and I am working on a
Tecumseh TC300 49cc Ice Auger
I am having a few problems with Assembly and remembering where certain parts and springs go.
I was wondering if I could get a link to a free manual for that engine.
It would be greatly appreciated!
Take Care,
Joe
P.S Sorry ... in the Choose a Category section, There wasn't an engine category...
Please Still Help... :) Thanks!
  • 1,512 Answers
Hi there, glad to help. You can get an exploded parts type veiw here
Posted on Feb 29, 2008
What year is a model 76 jiffy ice auger
The model 76 ice auger was made over a number of years and is probably still be in production. If it has a Jiffy engine, it was made before 2011 ("2500 series"). If it has a Tecumseh engine, it's 2011 or newer. Your best bet for getting the age is to find the serial number on the auger or the engine and contacting the manufacturer. Info source: http://www.jiffyonice.com/EComStore/pages/operatingmanuals.aspx
Feb 11, 2015 | Refrigerators
No spark in my toro 38080 mod# snowblower,new plus,new gas ,fuel line,primer bulb,line, no spark
The Toro 38080 was made from 1979 - 1993.
With it not producing a spark then you have an ignition system problem. Depending which Tecumseh HM80 engine setup you have you may have either an internal ignition system or external. By this I mean under the flywheel or external to the flywheel. There was also hybrid system that was both internal and external.
This engine could either points based system or a CDI all in one coil pack.
Now if it is an internal points systems it will be major an under taking for someone that never worked on one these engines as if you replace the points the ignition system must be re-timed. Note that where a few fix time setups. You might get lucky and it just dirty contacts which can cleaned without up setting the timing. To gain access to these points the flywheel must be removed.
Probably the best to do first is to download a copy of the service manual to see if this something that you can do or if you what to get a small engine mechanic that is experienced with Tecumseh repair to do.
Ignition system info starts on PDF page 67 (manual page 63) in the following manual. It will explain on how to test and repair the systems involved.
TECUMSEH-SERVICE--REPAIR-MANUAL-3HP-TO-11HP-4-CYCLE-L-HEAD-FLAT-HEAD-ENGINES-.pdf
Dec 27, 2014 | Toro Garden
NEED carb settings for AV520 TECUMSEH
My eskimo ice auger with a 3hp 2 cycle engine. Model number is AV 520. Starts and Idles very well. Does not seem to get enough gas at the high end or want to run wide open. Any ideas?
Jan 05, 2011 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
Small hole on carbuerator opposite where gas hose connects leaks
perhaps there was a hose on/in it at one time cause it sounds like an over flow/vent.
Apr 18, 2010 | Garden
I've lost my manual for an Eskimo Ice Auger and not sure what the gas/oil mixture is. Can someone help? Thanks
The gas/oil ratio is 50:1
GAS/ OIL RATIO:
1 galllon 2.5 ounces 50:1
2 gallons 5 ounces 50:1
5 gallons 13 ounces 50:1
Jan 24, 2010 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
I lost the gas cap from my Jiffy model 30 ice auger. The cap must be a vented cap. John It's an older model 30, from the 1980's
Hello! Go to the following link to acquire a vented gas cap for your ice auger.
www.outdoordistributors.com/Tecumseh/tfuel.html
Guru..........saailer
Dec 27, 2009 | Sport & Outdoor - Others
Need help orienting the Tecumseh TC300 carburetor spacer
what need to do is place the small hole on the block side and u shape the carb to make air chanel
Mar 15, 2009 | Garden
Despite changing the sparkplug and proper choking, etc. no start
The most likely culprit is a clogged carb - a very common problem indeed on Tecumseh motors. Pull the carb off, open it up, spray everything with cheap carb cleaner (especially the bottom "bolt" that hold the float cover making sure it sprays out of at least two sides as that "bolt" is also the jet), make sure everthing lines back up as you pulled it apart and now try to start it up again! Bet it works, I see it all the time on small engines left with small amounts of gas in the system. Good luck, and I hope that gets ya runnin!
Mar 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
