Question about Coleman Mach 15 Air Conditioner
Not working Hello I have chcnged out the tremastadt and the control board and i als checke my 12 volt fuse and my 115 braker and still my unit does not work what else can i do or try. My e-mail add is if you need to get in touch with me i need help quick i am living out of my camper in Texas and it is getting hot. Kind regards Hans.R.Warren
  • Anonymous May 11, 2008
    Cant say I have the same problem but a RV dealer said make sure you aren't using a standard extension cord. Connect the RV cord directly to the power source. Maybe this will help.
The fan is not working
Posted on Sep 21, 2008
  • 288 Answers
If absolutely nothing is working, and you are getting 115v, changed the fuse, like you said. Then the problem may be the transformer.
Posted on Mar 05, 2008
I have a 2005 jayco feather light with 12 volt issues I exsperiance a power spike fried the convertorreplaced it now I have shore power 12 volt power but my AC furnace and fridge are not working
The furnace and fridge both have control boards that may have problems. First check both circuit boards for built in fuses. Hopefully this is the only thing gone Replace the fuse and you should be good to go.
Aug 29, 2017 | RVs
My 2004 Ford Escapes radio wont work and it doesnt let me lock my doors when the car isnt running it also doesnt ding when the car doors are open. what is happening?
Hello Al,
Does your dash display a flashing "service soon" indicator?
Have you checked for fault codes?
You have a good battery, your ignition switch is powering up the vehicles dash board and the vehicle will start and operate normally....?
Any lights on the radio display?
Check for 12 volts on the radio power power? check for 12 volts across the accessory / radio position in the fuse box. No power but fuse is good...wiring issue in the harness.
Power across fused circuit no power to radio check radio's in line fuse...fuse good? ... radio bad or disconnected speaker wires.
Make sure all your vehicles grounding positions are clean and tight.
When you say your door locks don't work are your talking about the switch on the door or the remote fob?
Check your owners manual to check for any radio reset info.
Jul 25, 2016 | 2004 Ford Escape
have the voltage regulator system checked
in the regulator the voltage controls the amperage allowed and it that unit is not working properly then there will be no current out put
that regulator could be part of the control board for the main ac out put and may have developed a fault in the section for 12 volts on the board
there is a limit on the charge rate for the battery and if it is exceed it may have damaged that circuit or possible blown a fuse in the amperage circuit
May 07, 2016 | Buffalo Tools Electrical Supplies
I forgot to switch the current from 230 to 115 but
the fuse controls current flow and will not blow from incorrect voltage unless the unit being used has burnt out and shorted . with 230 volts on a 115 volt unit I think that the item will be destroyed unless you are lucky enough to have an overload reset button somewhere.
Sep 11, 2014 | Cars & Trucks
Does not cool on gas or 110 volt
Do you have any lights working on the front panel? If not most lower circuit boards have a small fuse on the circuit board. shut down ALL power before checking for the fuse.The lower board has both 115 volts as well as 12 volts. If the lights are working on the front panel then most likely the lower circuit board is faulty and will need to be replaced.
Mar 08, 2014 | Dometic RM2652 Refrigerator
Carrier gas heater
You may have a defective control board or blower motor. You will need to find on the main control board the location where the blower motor (marked heat) is connected. Using a volt meter, after resetting the limits and restarting unit, you will need to check and see if the board is supplying 1115 volts to blower motor (between the blower heat terminal and one of the neutral terminals on board). Also have someone hold in the door safety switch, or put a piece of tape on the switch, The switch will pop out when the bottom furnace door is removed, this is the normal location of control board. As the furnace goes through its normal cycle and prior to locking out on safety (limit opening) you should get 115 volts from the board (terminal marked blower / heat). If the board does not put out 115 volts, then the board is defective. If the board puts out 115 volts and the blower does not operate, the blower motor is probably defective, there is one more check to do. Close the door and put your system in cooling, see if the motor starts, if it does, then the low speed (reactor) is defective and motor needs replacing. If the motor does not start in cooling mode, you may have a defective capacitor. Check all of the above first and see what happens. Good luck, and be careful.
Dec 07, 2011 | Heating & Cooling
Blower motor quite running. Checked all brakers for the furance. none were tripped. Do the 110 volt motors have a mortor overload reset?
Hello, the blower motor will stop running for one of three reasons 1) bad control board 2) bad capacitor 3) the motor itself is bad Usually once the motor cools off the overload will reset .
Jul 20, 2011 | Heating & Cooling
No 12 volt power to duo therm comfort control box
check if you have 240V and then 12V to the secondary of the transformer if none then its your transformer that is faulty
Aug 02, 2009 | Dometic Rooftop RV Air Conditioner
Rf top ac on rv keeps blownig the 3 amp fuse
The 3 amp is 12 Volt protection for the control board. If that fuse is blowing instantly, then you have a short in the 12 Volt system somewhere. More than likely it is somewhere between the Thermostat and the control unit. Check to see if you have 12V at the thermostat. If so, then disconnect the red wire from the thermostat and the red wire at the control unit. At the control unit side, use an Ohmmeter to see if you have continuity with ground. If so, that wire is the culprit. If not, reconnect the red wire and continue to the next wire. Do this until you find the wire that is shorted to ground. Of course, the ground wire will not be checked.
Hope this helps,
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Aeg f88050im
Hi i just repaired mine. There was no fuse in it i found the timer control has a tranformer that goes from 240 volt or 115 volt in USA to 12 volts only the on off switch worked .
Oct 31, 2007 | AEG 24 in. Favorit 50730W Free-standing...
Coleman Mach 15 Air Conditioner Logo
56 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
