Question about SanDisk Sansa e250 MP3 Player
Key locked my unit displayed "key locked" and always shuts down. Please help
  • 1 more comment
  • adyjosue Feb 29, 2008
    Thanks! thanks so much John
    God bless you!
    Hi John or everyone,
    My e250 now displays "connected" to the PC but actually
    i can't located it in the windows explorer. Can't upload mp3 files.
    Please help.
    Thanks so much.
    Adyjosue
  • adyjosue Mar 03, 2008
    Hi John,
    You're great! Thanks for the help.
    More power!
    adyjosue
    Problem Solver:
  • 14 Answers
Try unlocking it by switching the switch on top, of the player by the earphone plug, from red/orange to white.
Thank you and please respond with any comments or more questions.
-John-
Posted on Feb 29, 2008
  • John Veerkamp
    John Veerkamp Mar 01, 2008
    Try changing the USB mode in the settings. If that doesn't work try downloading the firmware updater located on the sandisk website. Then run the update.
    -John-
Pass lock reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Nov 05, 2013 | Precor Exercise & Fitness
'Steering column locked' is displayed when key
I assume the car is locking and the alarm is working correctly? Try leaving the car locked then open the drivers door using the key, as soon as you open the door you should hear a chime - this is counting down to sound the alarm. Put your key into the ignition as soon as you can and try starting the car - if the problem is the same it would point to the key possibly having a faulty transponder within it or the locking module sensor or unit cannot see the key at the ignition barrel. have you another key to try. (The key itself has an identity separate from the key fob part) You will need to visit a good repair shop or the Jaguar main dealers who will have the equipment to scan the system to identify the faulty part. Other possible scenario is that there is a large current fault that is draining/shorting the system as you attempt to start
hope this helps - good luck.
Aug 01, 2011 | 2000 Jaguar S-Type
It always restarts in normal mode but does not restart in safe mod.whats the possible problems?
Sorry to read about your problem, I hope this helps you out.
you have to force the unit to start in safe mode.
To start up in safe mode:
Shut down your computer and wait 10 seconds.
Press the power button.
Immediately after you hear the startup tone, hold down the Shift key.
You should press the Shift key as soon as possible after you hear the startup tone, but not before.
Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Computers & Internet
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
How do I reset
Hi!
Press the Set button to turn on the unit (once programmed, tapping a Personal
Key turns on the unit.) The unit will beep to confirm activation, the Personal Key
numbers (1,2,3,4) will be displayed, and the display will flash.
If you don’t operate the unit for sixty seconds after the unit has been turned on, the unit
will turn off automatically.
If you make a mistake or want to turn the unit off before you have finished
programming it, press the Weight-Only Key to force quit.
Press the Up/Down buttons to select a Personal Key. Once you reach the
Personal Key number you wish to use, press the Set button.
The unit will beep once to confirm.
An arrow icon appears on the left side to indicate age setting.
Use the Up/Down buttons to scroll through numbers.
When you reach your age -press the Set button.
Use the Up/Down buttons to scroll through female or male,
Female/Athlete and Male/Athlete settings, then press the Set button.
Use the Up/Down buttons to specify Height and
The unit will beep twice and the display will flash all data three times to confirm the programming.
The power will shut down automatically.
Good Luck! :)
Cathy
Oct 21, 2009 | Tanita BC 554 Ironman Innerscan Body...
Pt cruiser disable alarm
battery of car is zapped of energy...not sure if alarm system to blame, after driving it for a few minutes..clock and radio display lights turn off, horn can barely be heard...sometimes, motor shuts down completely. have had to put in 2 new batteries in just a matter of 2 months?...any idea what this may be?
Oct 06, 2009 | 2001 Chrysler PT Cruiser
Key lock
Hi..there,
Well, open your onscreen display from the monitor and use - (-+) guide you to OSD settings and look for OSD lock to unlocked. And that it... Have a good one!
Oct 13, 2008 | LG Flatron L1750S 17" LCD Monitor
Cap Lock key trouble
hi sound like your having a region problem
go in to start then your contral and click lang/region then click change keyboards click this and select the contry you need and apply your setting .
now try and see if this works
hope it dose
all the best thanks
May 24, 2008 | Computers & Internet
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Lock key on screen
Hold down the "display" button on the remote until the picture comes back. The manufacture phone number is 1-866-220-7116 for future reference. (Just in case) Thanks! //D
Apr 25, 2008 | Computers & Internet
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
