Question about Pioneer PDP-5071HD 50 in. Plasma HDTV
5071HD switch, power supply problem??
The blue light blinks several times then pauses then blinks again. If I unplug and plug it in the TV will work but if the switch is pushed the remote does not work and I cannot get the TV back on until I unplug again. I just got the TV back from repair, it used to turn itself off and also it would just say "Warming up ..." and not work. My TV is less than a year old. Boy, I think I got the lemon.
  • Anonymous Sep 14, 2008
    maj
I need to purchase the power supply for a Videonics MX PRo video switcher.
Please e-mail me to zgarci@bellsouth.net
Posted on Nov 14, 2008
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Posted on Jul 31, 2008
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My Sony Trinitron has stopped working mid viewing. The on/off/stand by light just flashes. Any idea how to get the TV back on?
You can try unplugging the TV power chord, leave unplugged for several hours, then plug back in and try it.
If no results you will need it serviced as there are many possibilities. If the light is blinking in a pattern, example flashes three times then pauses then flashes three times again, the number of times it is blinking can give the servicor a clue as to what circuit is at fault.
Oct 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA D52W19BYX2 power light blinks once pauses, blinks a 2nd time, pauses, and blinks a 3rd time. Wait about 65 secs and it will do it again. Happens whether I use the remote or the switch on the set. Also,...
try unplugging the tv overnight, then plugging it in when you want to watch it.
i guess there is some safety switch on the processor inside the tv itself that kicks itself on...stupid.
that is the only "band-aid" i have found that works
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hitachi power light blinking
Does anyone know how to fix this very common Hitachi problem without paying a repair man? And if you did pay a repair man did they fix the problem, and how much was it? I absolutely LOVED this TV before this happened. :(
Jun 21, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Open Questions:
Pioneer PDP-5071HD 50 in. Plasma HDTV Logo
392 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
