I have an external usb/fire wire combo i-rocks hard drive. I partitioned the drive into two folders, and now, when I turn on the hard drive and plug it in to my mac it only reads the smaller folder that I use to back up my school files, but not the one with all my music and movies! If you can help me out with this problem, I'd really appreciate it. I'm running Mac OS X Tiger 10.4.11.
    Sergeant:
  • 349 Answers
I know nothing about Mac's ,but how lucky was you to still have access to your school files .
but i suspect if you use the same program you used to partition the drive and return it back to the way it was ,you should be able to see your movies & songs. or run the program to set the folder as the active folder.
good luck
Terry
Posted on Mar 11, 2008
Buffalo hard disk
Is this an external hard drive connected via USB? Your USB port may not have enough power - try a different USB port to see if that works..
Jan 17, 2014 | BUFFALO Computers & Internet
Transfer stuff from a working and put it on another hard drive
The easiest way is to connect your hard drive to an USB hard drive adapter or USB hard drive dock, then plug this USB adapter ot dock into the USB port of your computer. The computer will see this as an external storage device, you can then open the various folders and copy the folders or files to the computer,
If you want to copy these folders or files to another hard disk then connect the other hard drive to the USB hard drive adapter or USB hard drive dock and plug it into your computer and copy the folders or files from your computer to the external hard drive.
Mar 28, 2013 | Maxtor Hard Drive
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
I've been using my windows formatted external hard drive in my macbook pro in the past week and everything was working well. Until today, I was deleting unnecessary files and folders. I encountered an...
Were those files and folders something like System Volume Information, System Restore, Recycle Bin, and Desktop.ini? If yes then these are the folders that store the data about what is in the NTFS partition - deleting them makes the partition unreadable.
To recover your files from it you must install this program in a Windows pc
http://www.softpedia.com/get/System/Back-Up-and-Recovery/EASEUS-Data-Recovery-Wizard-Free-Edition.shtml
and run it. A better but paid program
http://www.easeus.com/datarecoverywizard/recover-formatted-partition.htm
Jun 10, 2011 | Samsung G2 Portable External HX-MU064DC/...
I have an i-rocks 3.5 usb/firewire combo external hard drive that seems to be malfunctioning. When i turn it on, it doesn't boot correctly and my computer doesn't recognize it. It continues to make this...
The clicking isn't a good sign; it means the drive is being repeatedly told to start rotating but it either can't start or come up to speed. There is a problem called 'stiction' meaning that the head(s) are somewhat 'glued' to a disk surface. Haven't heard of this problem in recent years but it still may be possible and not as likely with the extreme shrinkage of head size..
BTW, the actual drive probably has a different name and model number but would have to be removed to see the label.
Sep 05, 2010 | i-rocks External Hard Drive Enclosure -...
Recycler folder virus
You don't have a virus, you have the folders without an executeable link. Use windows explorer to delete the files you want to get rid of.
Sep 07, 2009 | Microsoft Windows XP Professional With...
Trying to read external HD, unknown partition
I see that you have a loss partition of your External HD. It is totally damage partition.
Here's what you do Replug your External HD to another PC if it is OK. Maybe its not the same will appear on your PC too.
Unknown Partition are likely big trouble to us if we have needed files inside.
Partition on every HD, External or USB are very needed, if you lose it. Then again reformat that to use again.
Hope its not gone. Good luck!
Aug 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Partition external hard drive
Yes a 1 TB externald hard drive can be partitioned. Yes its safe to store files on the drive and remove them from the computer as long as they are not files that are part of the windows system. Its not necessAry to have them on the pC and on the drive but of course its safer if you do.
Jan 18, 2009 | Seagate FreeAgent Pro 1TB External USB...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
Hooking up a
Your external drive has a choice of USB or firewire, so only connect with the USB cable.
Dec 05, 2007 | Western Digital External USB 2.0 80 GB...
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
