Question about Yamaha DVX-S100 System
Sub connected center speaker does not work
Five speakers are connected to my sub. I've tested all five by moving it around and testing. All five works. When I connect them correctly, my center does not work. Someone at Best Buy told me it's either the receiver or the sub that's not working. What can I do to make it work.
  • 4 more comments
  • brettv Feb 29, 2008
    No, it does not work. I've clicked on the "5-channel stereo," I only hear four.
    It does work. When I test it through the remote, it does may a brief, all be it small, sound.
    I guess it depends on how one interprets it as "ever worked." Like mention above, it does make a small sound, and the other four speakers work, so I'm assuming the sub works.
    When you disconnect all the speakers, and the TV is on, what should it sound like?
    Cool song. So, the sub suppose to sound low like that, or are you just cutting some sarcasm. Just checking.
    When I get home, I will disconnect all speakers, and the sub should sound like a regular tv.
    one question, what is the digital audio optical output, and what's it for?
  • 640 Answers
Its 5.1 dolby surrond,correct?When you try to shift from concert,theater,ect ect does 1 channel not work?
Posted on Feb 29, 2008
    Genius:
  • 3,587 Answers
Hmmm..that's a little weird..does the sub work on it's own? Is it powered? is it connected to right boost terminals ?
  • 4 more comments
  • Patrick Michaels
    Patrick Michaels Feb 29, 2008
    ok..so the sub woofer has some serious issues..has it ever worked?
  • Patrick Michaels
    well..the small squeaky sound from the sub woofer is NOT usual, as you might anticipate. That sucker has some serious driving power...I'm assuming you checked all connections? from both sides/
    let's just do this..disconnect all the speakers, and start with the sub only, and let's hear what that's go to say.
  • Patrick Michaels
    like a regular tv, if the main speakers are installed and on. connect ONLY the sub, let's see what's going on with that first, ok?
  • Patrick Michaels
    here's the Fixya.com international song video, for your amusement.
  • Patrick Michaels
    no..the sub has serious oomph...
    not sarcastic..just having some fun on a long Tech Thursday
  • Patrick Michaels
    that's for an optical signal for infrared reception
2 Suggested Answers
SOURCE: Center speakers (connected to Sub) does not work
Ok all you do is screw your brain into tiny pieces and then take your *** and twist it until it breaks off. Then connect those two and mush them into liquid and put it in a wire on the center speaker. I have a lot of experience so please do it and trust me.
Posted on Apr 08, 2009
I brourt a jamo sub 200 and five a102speakers but
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Aug 31, 2014 | Audio Players & Recorders
Please tell me all the connections on movie star 60+
Each of the five satellite speakers connect directly to an AV Receiver that you buy a separate device.
Here's the back of the sub. The sub either connects to the LFE Sub Out from the receiver to the white RCA/Phono Left Input. Or you can use speaker connection cables, AV Receiver front L & R to Speaker Level Inputs, and then Speaker Level Outputs to the front satellite speakers.
Aug 16, 2014 | Wharfedale Audio Players & Recorders
No sound from center speaker or subwoofer on HT-R500 av receiver
Take a left or right speaker that you know works and connect it to the center and test. Repeat for the sub.
Are you sure you setup the AVR correctly that it knows you have a center and sub?
Aug 16, 2014 | Audio Players & Recorders
Subwoofer outputs not functioning
Have a good look at your set up in regards to volume output to each channels .
you may have only one channel working due to volume turn down or a faulty connection from the console head unit .
After going through all these , i would suggest to get your sub amp checked as you may have a faulty amp .
Sep 28, 2009 | Bose Acoustimass 15 System
Do you have the "Phantom" option set on your receiver? That will give you these symptoms on Dolby Prologic...accordianman
Feb 29, 2008 | Yamaha DVX-S100 System
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
No Connection to Some of the Speakers...
Solved Problem! Hold down test/setup for 2 seconds, then cycle through and add each speaker back into the setup. Happened to me, it must have reset somehow. That's how you fix it!
Dec 27, 2006 | RCA RT2500 System
Yamaha DVX-S100 System Logo
193 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
