Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
Reddy heater TB100
My heater fans runs, I have gas, but it will not ignite? Just stopped working
2 Suggested Answers
hotuna
  • 288 Answers
SOURCE: reddy heater TB100 propane
Well it sound like you have all the components working. Try lighting it with a torch or long match or something. If it lights, then you may need to adjust the spark-er. You also may need to adjust the pilot. It may be too much pressure, which will blow out the flame, or its not enough gas. Make sure the pilot orifice is clear.
Posted on Mar 06, 2008
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Rlp35 reddy heater runs few minutes flames out, fan continues to run?
clean the sensor so that the control can have confirmation of ignition
Nov 11, 2012 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Starts up and runs for 30 sec. and stops.yes it has fuel
find the high limit switch an replace or see if fan runs if fan runs then the limit is bad replace
Mar 15, 2010 | Reddy Heater-30-55,000 BTU Variable
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
My Reddy heater does not run. How do I know what
i have a 115reddy heater it run for 3or4 mins then it shut off and blue some comes out what causing that
Dec 02, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater TB100 propane
Mar 01, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
244 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
