Question about Lexmark X1240 All-In-One InkJet Printer
Hello i have done everything to get my printer to scan, copy and print but it keeps coming up not communicating with the computer. what should i do?
  • 1 more comment
  • sweetpea08 Feb 29, 2008
    i have lefted my printer off all night and turned it back on the next morning and it still does it. you said to check the pause mode can you please tell me how to do that? thank you for your comment
    where do u find the pause button? all i have on mine is the on and off switch no pause button by it
  • sweetpea08 Mar 01, 2008
    i still can't get my lexmark printer to work wow i have done evrything that you told me plus have unpluged and changed my usb cord and it still doesn't work. i have uninstalled and reinstalled my disk about 5 times and nothing. please let me know what i can do
  • 796 Answers
Turn off the printer wait for 15 seconds and turn it on again....
this will solve the problem
Posted on Feb 29, 2008
  • 4 more comments
  • isaac johny
    isaac johny Feb 29, 2008
    also check that the printer is not left in the pause mode itself
  • isaac johny
    there will be a button pause/start.....
    if the printer is left in the pause it wont feed the paper at all....
  • isaac johny
    sometimes the print heads will become blocked. Take the catridges out
    and put a piece of toilet paper across the head and see if ink bleeds
    through. if not try moistening some kitchen paper and gently cleaning
    the heads.
  • isaac johny
    FOR SCANNING
    There should be an icon in the system tray (bottom right corner of your
    screen). It is white with different color blocks on it. If you hold
    your mouse pointer over it it says something like "Lexmark Imaging
    Studio". Right click on it and choose "Lexmark 1200 Series All-In-One
    Center". This will start the scanning application.
  • isaac johny
    last step
    1. if you enter the "printer and faxes" can you see your model printer there?
    2. if you can see the printer there is it the default printer?
    3. if all the above is yes, try to check to what port the printer is connected.
    4.
    if all doesn't work try to reinstall the driver do it while the printer
    is not connected to the pc, and after u reinstall the driver connect
    the printer to the pc. see if this work for you.
  • isaac johny
    ok ,,,try the other solution
Lexmark X73 Printing Problem
When you say that your all-in-one system will copy, but will not print from the computer, this tells me that there could be a connection problem between the printer and the computer. This is more then likely a driver problem. you will need to go to lexmark and download the latest drivers for your operating system.
But this could also be a broken or loose cable.
Apr 15, 2010 | Lexmark X73 All-In-One InkJet Printer
Until a few days ago my Model X3550 operated perfectly, now the unit will not respond to print command, although it will still copy and scan and perform all other functions. Simply will not print, get...
unplug printer. uninstall the printer drivers. restart computer. when desktop comes up, plug in USB for printer. Windows should recognize the printer. If not, try a different USB cable.
Feb 04, 2010 | Lexmark X3550 All-In-One Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
When trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
Jun 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
I cannot print pages from my computer. The message says no communication. I can fax, receive faxes, copy and scan. I just can't print from the computer, everything is connected.
try checking ur usb cable... if that is ok then check ur printer prefrence to make sure one it is ur default printer and two it is set to send print info to that printer
Nov 04, 2008 | Computers & Internet
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
Keeps telling me the printer isn't communicating with computer
Before I can help you I need the model and manufacturer of the printer you are having problems with. Also what operating system you are using?
Jan 10, 2008 | Office Equipment & Supplies
Lexmark X1240 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
