Question about Mpio HD-300 MP3 Player
Frozen MP3 player - MPIO HD300
I wonder if you can help. My mp3 player seems to have frozen. When switched on the logo appears, the HD can be heard spinning, there is single click, thereafter, nothing - just the logo. I've tried resetting but it's still the same. I've tried connecting it to the PC but it isn't being recognised. I've checked in 'my computer' there is no new hardware or HD300, nothing on 'safely remove hardware' either. Tried reformatting but it didn't work as the mp3 player doesn't seem to be connected to the pc. Battery charges ok & is fully charged. I have the exact same symptoms. Am running XP and WMP 11. The MPIO HD 300 is brand new. Battery charges fine. Displays "MPIO Ver. 1.20.03". Windows does not recognize it, but Device Manager recogizes it as a Hitachi hard drive. Tried to manually load the driver via the Device Manager, but it wasn't successful (system couldn't access the MP3 player). Totally stuck...any clues anybody?
  • 1 more comment
  • dwsmith98 Mar 03, 2008
    Thanks Jastababe, but I think you misunderstood my problem. Looking at the problem description - I can see why. First, I don't know WHY FixYa appended my Problem Description to another person's Problem Description! When reading it - it's impossible to determine where their description ends - and mine begins. Mine starts at "I have the exact same symptoms...".
    Yes, upgrading the driver is always a sound troubleshooting tactic. However, if you read both problem descriptions you'll notice that we both mention that Windows does not recognize the MP3 device. So I can't uninstall the older version software - or install the latest. It's impossible to communicate with it. That's the problem.
  • dwsmith98 Mar 06, 2008
    Hey Jasta,
    Thanks for trying to help. Let me give you some additional info. Am running a Dell dual core laptop with XP2 and WM11. After charging the battery on the MPIO HD300, the only function the device responds to is the ON function. It then displays the initial screen "MPIO, Version 1.20.03" (firmware version). That's it. I can't turn it off (without resetting it with a paper clip) as none of the other button functions respond.
    When attaching the HD300 to my laptop via USB cable, its screen displays a diagram of the device and a PC with an animated USB cable going from the device to the PC - attempting connection. It displays "USB Connect!". If I disconnect the USB from the laptop, the screen on the device changes temporarily with an hourglass image before turning off (at least I think it's OFF...the screen goes blank).
    NOTE: I duplicated all these tests on my other Dell laptop (same software), exact same results.
    Has your mp3 player ever been recognized by your OS?
    Not fully, i.e., "My Computer" does not recognize the device, but Device Manager displays it as a Toshiba disk drive...not as a Portable Device, and there are no Problem Devices shown. Under 'Properties', Device Manager says, "the device is working properly".
    Did your player come with any software at all?
    Yes, an MPIO Utility, USB Device Driver and WMP Plug-in. Since it did not recognize the device I uninstalled it and downloaded the latest MPIO Utility (ver. 1.0.6.0) and Device Driver. Have since installed the latest MPIO Utillity on my laptop (but obviously I can't install the newer Device Driver).
    After installation I opened the MPIO Utility which displayed "Format & Config", "Set Config" and "Firmware Upgrade" buttons. Nothing happens when I click the buttons - other than the Flash click state...no error messages...nada.
    Have you tried installing Itunes, or yahoo music jukebox to see if your player gets recognized.
    No, since Windows can't recognize the device.
    Is there any music on it, as in the factory music?
    No way to tell. Can't get past the initial screen "MPIO, Version 1.20.03". Can't access the main Menu and none of the other button functions respond.
    When it's not plugged in, can you listen to anything at all that was factory installed.
    Nope...no functionality.
    Do all the bells and whistles work before you plug it into the comp port?
    Nope.
    Is that port compatible with your player, or do you need to upgrade to a usb 2.0 version?
    No I don't need to upgrade...the HD300 is USB 2.0 ready, here are the Specs:
    - Supports MP#, WMA, OGG, ASF formats
    - Plug and Play, no software required
    - USB 2.0
    - Supports direct encoding
    - Built-in Li-ion battery (16 hours)
    - Built-in FM tuner & Mic for recording
    - Innovative touch sensor button
    - Upgradeable firmware
    There still are a lot of questions that need to be ruled out...Please answer as many as you can, so I can help you better with your problem>
  • dwsmith98 Mar 07, 2008
    Can't return it...bought it on eBay...a $170 rip. But thanks anyway.
    Scholar:
  • 117 Answers
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Posted on Feb 29, 2008
  • 2 more comments
  • Terry Lynn Deschamps
    Terry Lynn Deschamps Mar 03, 2008
    Unfortunately, Did your player come with any software at all?
    Is there any music on it, as in the factory music? When it's not plugged in, can you listen to anything at all that was factory installed.
    thanks
    Jasta
    Terry Lynn Deschamps Mar 06, 2008
    Wow...now I can say it is the player itself. I like supporting clients who have the patience to give me the specs. Thank you for that..
    From my experience, all mp3 players purchased from the store, have factory installed songs, files and even parts of audiobooks, if tha option is on that player itself.
    We've gone over everything, from start to finish, and you've ruled out that everything is working on your computer.
    Since your computer does recognize it, and since it tells you that your usb is connected, as well as having it being seen in device manager, I would return that particular mp3 player or another. WHEN you are in the store, open the package with a tech beside you and make sure it's working. Sometimes we do get peripherals that are DOA..
    ~~Jasta~~
    Terry Lynn Deschamps Mar 08, 2008
    Awww.....
    When you purchased the item from Ebay...was it as IS? Was there no warranty on it what so ever....and if that's the case that it doesn't work....have you contacted the "seller" to request your money back on an item that is DOA....I would pursue that...if he will NOT resolve it...report him to EBAY and leave negative feedback.
    This type of thing happens all the time...unfortunately...
    Good Luck
    You might want to try this.......
    Go to www.mpio.com and then to
    MPIO Managers and drivers,choose this driver....: MPIO Utility
    Ver.1.0.1.3, which is labeled as only working for the FL300 and FG100
    Download that driver..yes..I know it's not labelled for your specific player...but let's try this one last ditch ok..
    Let me know if we have it working....
IPod nano is frozen
try this :)
turn the hold switch on, then off.
then hold down the "Play Button" and the "Middle Button" at the same time, until you see the apple logo on the screen. :)
Sep 26, 2009 | SanDisk Sansa c140 MP3 Player
Mpio hd300 mp3 player wont turn on
my ******* zen vplus is not turn on at all i reset and it still not work
Apr 17, 2008 | Audio Players & Recorders
BRAND NEW MPIO HD300 Completely DOA!
It's a reasonably straightforward task. There are 2 screws at either side (near the top) of the player. You'll need a small Alan-key to remove these. Once this is done, carefully prise off the back cover and you'll be able to see the battery - at the back. Just un-clip the battery cable. - You might want to check the connection in the first instance, if however, the battery needs replacing see replacment battery model number below: -
UP325385A4H-UP325385A5H
Hope this heps
Nam1
Feb 21, 2008 | Mpio HD-300 MP3 Player
Frozen - Mpio HD-300 MP3 Player Problem
Sounds like the player can't see it's hard drive, not much you can do if the drive is dead. If it's under warranty then have it fixed.
Jan 18, 2008 | Mpio HD-300 MP3 Player
Try to reformat using your USB 2.O, with The Super-Reboot MP3 Software, may take up to 24/48 Hours to Reformat
MPIO HD 300 Freezes/Computer won't recognize
1. there is a reset button if the player is stuck, there is a hole on the front panel use a paper clip.
2. Hard Drive probably got disconnected from the FPC cable, you might need to open the player to fix this issue
Dec 10, 2007 | Mpio HD-300 MP3 Player
Mp3 player repair
Hi
It's called the FPC cable, you can try to connect Mpio America
rma@mpioamerica.com
Sep 24, 2007 | Mpio HD-300 MP3 Player
MPIO MP3 HD300
This should do it This will do the trick http://www.mympio.com/index.php?topic=13.0
Aug 17, 2007 | Mpio FG200 MP3 Player
Frozen screen/ can't turn it off
Try the reset button which is pin-sized hole on bottom right when looking at the HD-400. You will need paper-clip to press it.
Jan 16, 2007 | Mpio HD-400 MP3 Player
Mpio HD-300 MP3 Player Logo
342 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
