Question about Sony KDF-E42A10 42 in. LCD Television
Cant get HDMI input to work
I have a comcast motorola dvr with a HDMI input. So I hooked them together using an HDMI cable.But I get no picture when I use the HDMI input. works with the S video and componet video but not the HDMI. Any help would be greatly appreciated.
  • Anonymous Mar 24, 2008
    Same problem for me, tried connecting my xbox 360 via hdmi and got nothing. Component works fine though.
  • sushy99 May 31, 2008
    I have had the same problem... I used to use a HDMI to DVI hookup for my cable, but recently had a DVR upgrade and it is a HDMI to HDMI. I bought a cable and at first it worked, but then I had to disconnect it and when I reconnected the signal was dead. I even exchanged the cable to no avail... I am very confused on what I should try next.
    Scholar:
  • 137 Answers
Hello Kman69,
You have one of two most likely problem.
(1) You have a defective HDMI board. This is most likely the case with your set.
(2) You may need to do a software upgrade. This is not common with the Sony, but i have done my fair share of upgrade.
I have the board in stock, just in case you need it. The software is available (free) and is very easy to do.
Best regards
circuitcity
Posted on May 28, 2008
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Sony KDF-E42A10 42 in. LCD Television Logo
361 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
