Question about Precise Heat KTES2 Electric Skillet
Temperature control unit .
The temperature control unit that plugs into the pan has a loose paper on which the different temps are printed.  I am fearful that it will come off and I won't be able to tell what temp I am setting for cooking. Could the whole unit be replaced or what would you suggest?
  • 57 Answers
Well, you haven't said what kind of skillet it it, but I would think that in most cases you should be able to get spare parts for it.
This is quite a comprehensive list of small appliance part suppliers. I recommend you go to this site, once it opens in your web browser, press "Ctrl f" which will open a little word search window. Type in "name of company" in the space and click "next". Each time you press next "name of company" will be highlighted in the next parts company that sells that companies parts. You should then be able to find the web-site for that parts company by scrolling down a bit further.
Or you could do what I would do. Find a way to either score the lines into the plastic of the old controller or design and print a replacement paper on the computor. And of course there is always glue!
If you found this useful, please vote. Thanks.
Posted on Mar 02, 2008
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
Cooling fan wont turn on
you are expecting the wrong temperature unit to control the fan. The temperature sender unit controls the temperature gauge and the temperature sensor unit controls the fan operation. It allows current to go to the ECM and when a pre set temperature is reached the ECM activates a relay and the fan starts . Two completely different units to do two different jobs so if it is doing what you say then there is a possibility that the wires are crossed or shorted.
Jun 20, 2014 | 1993 Dodge Spirit
Toner not stuck well on paper and can be easely erased by hand
Sounds like you have bad toner. or fusing area not getting hot enough to fuse to paper. I would try another toner cartridge. If problem goes away. Bad cartridge.
Feb 21, 2014 | Ricoh Aficio Mp4500 Mp3500 Cl7000 Ap3850c...
Laars Lite 2 Pool Heater max temperature too low
if hooked to a system increase temp if not try new temp sensor in heater
May 04, 2013 | Jandy Heater Temperature Control Assembly...
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
2001 dodge stratus engine temperature gauge spikes occasionally
Look for a loose connection to the temperature sender unit on the motor.
If all connections OK, you may need a new temp sender unit.
Jul 28, 2009 | 2002 Dodge Stratus
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at
Jul 13, 2009 | Kitchen Ranges
E002 canon 6317
1)due to fuser unit temperature control fault.
2)try to reset the machine by tuning on and off
3)fixing thermister or thermoswitch faulty due to cannot maintain fixing heater temp causes E002 appear.
4)check any paper roll over the surface of fixing roller.try to remove it.
5)fixing roller or fuser roller located near to printing output.
Jun 10, 2009 | Canon imageCLASS D761 Copier
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Heater/AC control no longer allows change in temperature
You have one of two possible problems.
1) The temperature shaft retention nut is loose behind the knob
2.) The wires to the potentiometer part of the temperature may be broken.
Either one is common to this vehicle. The replacement of the AC controller is about 900 dollars. If the wires are broken, they can easily be reattached to the circuit board via soldering. What you would have to do is remove the control box from the dash, and disassemble it. Once the unit is apart, there are 3 wires from the temp knob to the circuit board that need to be re-soldered. The unit CAN be repaired, as opposed to the expense of replacing it.
Apr 23, 2009 | 2006 Toyota Highlander
Precise Heat KTES2 Electric Skillet Logo
243 people viewed this question
Top Precise Heat Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Precise Heat Kitchen Appliances - Other Expert? Answer questions, earn points and help others
