Question about Bissell 1715-G Spotlifter Bagless Handheld Vacuum
Bissell Spot Lifter
My spot lifter won't spray water. The suction is fine. The support lady from Bissell suggested cleaning the hose, but she didn't say how to do it.
Ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Posted on Mar 21, 2009
    President:
  • 1,673 Answers
I have found that some of these models that have a heater in them will clog up from calcium, if the heater clogs, then water cannot flow. You will need to dis-asemble it, take the lines off of the heater, using a nail or pin, clean out the ports that the water lines were hooked to, blow thru it afterwards to see if it is clear. If this is the problem, put it back together, then run a solution of vinegar and water thru it for several minutes to clean out the flow solution.
Posted on Feb 29, 2008
  • Lauren Junge
    Lauren Junge Feb 29, 2008
    Gorgot to mention, Bissell has obsolated must parts for this unit.
SPOT BOT NO SUCTION
Hey Courtney! Sorry to hear about the suction problem on your SpotBot. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1040&cid=ccsocial
Jan 04, 2013 | Bissell SpotBot Robotic Wet/Dry Vacuum
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
My bissell spot lifter model 1716 won't spray water at all, how do i fix this?
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Sep 20, 2012 | Bissell 1716 SpotLifter PowerBrush
My Bissell Proheat has stopped suctioning the water solution. It has worked well in the past, but the last time I used it the recovery bladder had just a small amount in it. Could it be stopped up?
I have this machine too. IF the soap dispenser does not have anything (even water) in it the water sprayer will not spray. Sometimes the water valve from the tank has an air bubble in it. Remove the tank and push up the valve. A little water will fall out and then put the tank back into the machine. These fixes assume the water isn't being picked up because it isn't being sprayed. You do want to determine if the machine is providing suction. Turn the selector to the hand tool and with the handle all the way up (since that makes the conduit for the vaccuum from the top over the tank to the handle) and see if there is suction from the hand tool. If there is no suction from the hand tool and the handle is pushed all the way forward then the machine needs to be repaired. I would buy another from ebay or craigslist since the repair will be very costly. I have owned several and this has been my experience (I stll own two and a spot lifter too.)
Jul 07, 2009 | Vacuums
Bissell 1715-G Spotlifter Bagless Handheld Vacuum Logo
513 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
