Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic PT47WX49E We were just given this tv and it has a shadow or out of focus picture with red and blue being the prominent colors, is it worth repairing?
    Novelist:
    Scholar:
  • 96 Answers
Here some info what to do before sending it to the shop
Open the back cover, check while the ptv is on if it is arking, I would suspect bad horzontal flyback, this would difenatly cause this,
Another issure is this the last person before you play inside the ptv on the focus block or tampered with the crt, well don't this is the worse move you can do.
Does it look like or tring to explain it is not our of focus but out of alinment, well is so your totaly in for a different ball game, it is convergence problem, this or the two big ship's that everyone just loves so deapely that they just want to scream, this ic's again or assesabel by the back only and has the part % starting with STK , if the picuture is diffenatly out of focus then this is not your problem.
Last take a long coffe brake and try by alimating what could cause this, I can almost garranty if it is out of focus then I would suspect the horizontal transformer you should know by the noise it is making, arking.
If you need more info just recontact me
rlandry@vianet.ca
Regards
What about bob
Timmins, Ontario
Home of Shania Twain.
Posted on Mar 08, 2008
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Distorted Color and geometry of Picture
replace stk 392-110 ( or stk 392-150 same number) , check resistor 2.2 ohms for open or burn beside STK IC's
Apr 13, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Dec 27, 2008 | Panasonic PT-51HX42 51" Rear Projection...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Blue color problem
same here, fuzzy blue when trying perfect focus, all other colors are sharp. I have the 2 STK392-040 package
Feb 24, 2008 | Samsung HCN4226W 42" Rear Projection...
Focus problem
If it's under warranty call the manufacturer, in every case I've seen this it turns out to be the Optical Engine. Which can be a very expensive part to replace not to mention quite labor intensive. but it definitely sounds like the OE is dead or not calibrating properly.
Jan 29, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
128 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
