Question about KitchenAid KGRA806PSS Gas Kitchen Range
Oven door is locked
I was broiling cheese on french onion soup when my daughter slid the cleaning lock as a joke to keep me from the soup. Now, the door won't unlock. I tried unplugging, i tried putting it in cleaning mode(only 15 min cuz soup is burning in there) WHAT DO I DO?
Patty
  • Pattyz Mar 03, 2008
    IT WORKED
I took the grids off the burners and gently pushed a screwdiver in the gap between the top of the stove and the area where the lock is. Then i slid the lock to left. Presto! open!
Posted on Mar 03, 2008
I have a ge profile oven model starts pt 916 when i broil food the "locked" light flashes, i usually keep the oven door open so i can watch the food after about 5 min the locked light goes off
The only thing spring to mind Mary is that you somehow selected a cleaning cycle which superheats the oven and turns burnt on fat and grease to charcoal. The cleaning cycle never finished and the stove remembers it. The light is flashing to remind you. When the cleaning cycle is in progress, the door locks until it is finished.
Either remove the wall power plug or flip the breaker and leave it overnight. It _should_ erase it from the memory. Or you have to compete the cleaning cycle as per the instruction book.
Sep 05, 2016 | GE Ovens
Coks essentials coontact grill cheesburger
These burgers are broiled, or use your grill and serve on toasted hamburger buns.Ingredients:
  • 2 pounds ground beef, lean
  • 1 tablespoon steak sauce, your favorite
  • 1 teaspoon Worcestershire sauce
  • 1/4 teaspoon hot pepper sauce
  • 2 teaspoons salt
  • 1/2 teaspoon pepper
  • 1 1/2 cups shredded American or mild Cheddar cheese
  • 1/2 cup finely chopped onion
Preparation:Combine ground beef, steak sauce, Worcestershire sauce, hot sauce, salt, and pepper. Shape mixture into 8 hamburger patties. Broil patties 4 inches from heat for 6 minutes. Turn and broil for 4 to 6 minutes longer, to desired doneness. Combine cheese and onion; place on patties then broil until cheese is melted. Serve on toasted hamburger buns.
Nov 02, 2011 | Cook's Essentials Cooks Essentials Arome...
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
After canceling self cleaning on my GE Hotpoint oven, I was able to unlock the door and open the oven door. When I try to use the broil or bake feature it keeps saying "un lock dor" The door is not lock...
You will need to allow oven to cool, the temperature is one thousand degrees plus while the oven is cleaning. Until the oven cools it will not open, this is a safety caution. If it will not open after it is totally cooled, it may be stuck, try pushing on the door or pulling it out a bit while trying to move the lever.
Always consult the owners manual when using the cleaning mode on your oven. Be sure it is fully cooled before cleaning any residue out of oven area.
Jan 28, 2009 | Kitchen Ranges
Locking door wont open
the self cleaning lock is stuck and I can't open the oven, how do I fix this
Jan 19, 2009 | Hotpoint RB757 Electric Kitchen Range
GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Apr 09, 2008 | GE JKS05 Electric Single Oven
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KGRA806PSS Gas Kitchen Range Logo
160 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
