Changing from MP3 mode to DVD on Kross player
I have a KROSS DVB-T/DVD Combo player, It has set itself on to MP3 and does not recognise DVD disc's. I don't know how to change mode from MP3 to DVD. There is nothing in the instruction manual either. Can anyone help me please?
  • ian_iam Apr 29, 2008
    Hi...
    I think I have the same unit as yours.. a Kross TS-2818 - mine does not power up any more... I think the power board hasd gone... Are you still using yours and would you be interested in parts ??
    Cheers
    Ian
Hi...
Cheers
Ian
Posted on Apr 29, 2008
KROSS Set Top Box / no manual/ would like to set it up and start for the first time / NO users guide...
Hi Ilmar, Connect the set top box up to your teevisions AV then turn your television channel on AV....CHEERS
Mar 31, 2016 | Televison & Video
I lost disk to install a kross webcam KR50WC
Go to Internet and open Google and type webcam model no or serial no and search. I share link open and download Driver.
http://www.driversimple.net/Camera-MP3-Player/Kross-KR50WC
http://download.driverguide.com/driv.../d1508636.html
Thanks.
TechSupportMart
Mar 06, 2014 | Computers & Internet
Kross 15" lcd tv model ts-15lcdtv
I have had this as a monitor. How do I change it back to TV mode?
Feb 20, 2013 | AOMNI Corporation Magnavox 15MF605T/17 15...
DVD not recognising the disc
Does it say anything like can't read disc, or just spins up and stops with no notification? Sounds like the DVD is scratched or maybe wrong format, its not a bluray is it? How old is the TV? If it hasn't played a DVD in a long time dust can collect on the lens, a Lens cleaner disc may help.
May 12, 2012 | Televison & Video
New KROSS DVD player has problems with USB drive
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Jan 10, 2012 | Computers & Internet
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
HELP! I Need a KROSS webcam driver 2.0. Thanks folks!
visit microsoft.com and on the driver section, ask for Kross webcam drivers. they will show you options whether they are downloadable or if you have to buy from them.
post a comment if you need further assistance.
wonder
Sep 22, 2009 | Computers & Internet
Hi I have a KROSS TS- 2818 DVb-T/dvd combo player that the remote has died on. This means that the unit is stuck on DVB and I am wondering if anyone knows how to manually change the unit to DVD. Have tried...
Not sure about manually changing from DVB to DVD but you could try and get the remote working first by pulling the remote apart and removing the red infared plastic part at the front of the remote, install new batteries and see try it out. Have seen this work on other remote units.
May 02, 2009 | Televison & Video
The DVD recorder would no boot up
Hello Ken,
Here are the things that you need to do to isolate the problem:
1. Make sure that there's no disk inside the recorder.
2. Turn off the power from the unit (not using the remote).
3. Unplug the DVD from the wall / power outlet.
4. While being unplug, hold down the power button for 30 seconds and plug it back in while still holding down the power button and then release it.
If that will not do any help, change the C18 and C36 (both 2200uf at 10v). the C18 and C36 are on the power supply and most of the time, they are Green.
Have a great day!
Apr 30, 2009 | LG Electronics LRM-519 Digital Media...
Won't recognize blank DVD+R disc
Try the next disc in the stack, and see if it will recognize the next one. If not, the problem is most likely the recording speed of the +R disc. Before you go changing disc types, however, I would also check the Record Mode you have set for the dub - if the REC Mode is set for XP, try changing the mode to SP and see if you have any luck. If it still won't work, try one of the tested +R discs:
SONY (2.4x, 4x, 8x, 16x)
TDK (4x)
Mitsubishi (4x, 8x)
Ricoh (2x, 4x, 8x)
-Tha Mp3 Doctor
Feb 14, 2009 | Philips DVDR3320 DVD Recorder/VCR
Televison & Video Logo
336 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
