Question about Nokia 6126 Cellular Phone
Install bluetooth im trying to install my motorola h350 bluetooth to my nokia 6126 phone and its not pickin up the blue tooth at all. what do i have to do to install it? i tried everything that is says to do in the users guide.
    Brigadier General:
  • 7,752 Answers
Well take it to a customer service rep and have them fix it for you......
Posted on Mar 28, 2008
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
Volume control on the left of my nokia 6103 is broken
while your in conversation with another person try using your phone volume, while your using your blue tooth it should be in bluetooth mode, dont forget to press set after youve turned it to the desired volume. good luck
Jan 24, 2009 | Motorola Mobility H350 Wireless Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
Connectivy
check the visibilty??
Aug 25, 2008 | Nokia 6126 Cellular Phone
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Nokia 6126 Cellular Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
