Question about Brother MFC 210C All-In-One InkJet Printer
Brother mfc210c how to refill LC41bk cartridge with a universal refill kit?
  • 832 Answers
Two ways to refill lc41:
drill a 2 mm hole into the brandname (e.g. O of brother ) on top of the cart. You can leave the hole open and leave the carts in the printer in future for further refilling ;-)
The cart can be refilled by inserting a syringe without a needle into the ink Outlet(!) at the bottom, too. Carefully press a 12ml for C/Y/M and ca. 15ml - 18ml for BK into the carts.
Anyway:
Do use DYE-ink only!
Important: You must mix the dye-ink with some 85%-glycerin alc. to keep the print head nozzels alive = 10ml ink with 2ml glycerin alc (drugstore).
For BK: 15ml ink + 1,5ml glycerin alc!
Posted on Feb 29, 2008
How to convert photosmart printer cartridge to refillable one
Yes conversion kits are available. I always recommend using a brand specific kit rather than the universal.
One company 4InkJets, claims that, "Our HP Ink Refill Kits are not universal kits. Each Refill Kit is specifically designed to work with a specific HP cartridge. Our refill kits are the best way to save money and still print at high quality. All of our HP Ink refill kits are dual refill kits which means you can fill up your cartridges twice. We also have clear and easy instructions on how to refill your cartridges. Our refill kits are backed by a one year 100% satisfaction guarantee."
You can reach them by CLICKING HERE:
CLICK Below for a video presentation on how the deed is done.
May 02, 2012 | HP Office Equipment & Supplies
I installed a compatible Office Depot black ink cartridge to the brother LC41BK printer, however continue to get the message "no cartridge installed - lift scanner cover and reinstall cartridge.
patthomas55,
Many times manufacturers use a sensor in the cartridge to defeat customers using "compatible" or "refilled" cartridges. In many cases you can just cancel out or hit stop or cancel several times to make the printer ignore the warning. If this does not work you will have to purchase the original equipment cartridge to be able to use your printer. I would think that you should be able to return the cartridges in question for a full refund.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 30, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
MFC210C wont print yell or blue only blk &mag. HELP!
Pull the cartridges out and them turn it off and then turn it back on then try placing them back in...Because the cartridges work on suckion.
May 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother printer manuel
The manuals can be downloaded free here.
The cartrages can be purchased from just about anywhere... I looked them up at www.tigerdirect.com and they go for about $25 for the black one and $13 for each color. You should be able to just buy the ones you need. Here are the part numbers for the cartridges:
LC41BK
LC41C
LC41M
LC41Y
Mar 16, 2009 | Brother MFC 420CN All-In-One InkJet...
Borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother 3240x
See this page. The models of Brother's cartridges for the MFC-3240C are as follows:
  • black: LC41BK
  • cyan: LC41C
  • magenta: LC41M
  • yellow: LC41Y
Jul 12, 2008 | Brother MFC-3240C All-In-One InkJet...
How To Refill?
Harry, you can use every DYE ink for brother printers. DO NOT use pigmented ink due to clogged filters inside the printhead!!!! The carts for mfc210 are filled with 20ml for BK and 11ml for C/Y/M. I use to refill 20ml only ink for bk and 10ml ink + 1ml printhead cleaner for C/Y/M. See here how to do that (LC900 refill): http://www.hstt.net/refill-faq/brother.html#LC-900 Refillen (Simply drill a hole into the brother brandname and leave it open!) I use a 20ml syringe and 3 12(10+2)ml syringes from the drugstore (ask your doc! It may be cheaper ;-)
Sep 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Aug 25, 2007 | Brother MFC 420CN All-In-One InkJet...
How can I refill my ink cartridges myself?
Be brave and have a go, buy the correct ink refill for your selection of cartridges, the packaging on the refill kits will tell you if your printer is included. Once you find one for yours, instructions come with it. I think your cartridges have plastic ones don't they? Make sure when you fill with syringe you follow instructions very closely to avoid air bubbles and always run a clean when you put it back in. I refill all the time, and each time i refill (i get 7-8 refills each cartridge now the way i do it) i am saving $80.00 both cartridges. This can be most of a thousand dollars a year for me.
Aug 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
281 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
