Question about Kenmore 63942 Dryer
Heating elimate is out
Im trying to change my heating elimate. I cant figure out how to get to it.
  • Gary Davd
    Gary Davd May 11, 2010
    remove the back it is on the right side
  • craig carter May 11, 2010
    what kind dryer model with filter in top are filter in door
  • 156 Answers
Are remove front panel lower below door it can also be there depends on dryer
Posted on Mar 03, 2008
Gibson Furnace 80% runs a full cycle, then takes too long to turn back on again. Customer says runs about once an hr
Sounds like a over heat is holding the heat off taking to long allow a call for heat. A limit holding off .
Dec 22, 2017 | Gibson Heating & Cooling
Why does my fryer says shorted probe
You need to replace the thermostat probe. That probe controls your heat and prevents it from over heating or not heating so if its out it has no way of being able to do so so it stays off. I couldn't find part but call manufacturer and provide serial number and they will get you everything you need and even help with any small questions.
Aug 26, 2014 | Vulcan Hart 2GR45DF LP - 45-50-lb Fryer w/...
I have a kenmore 400 dryer model# 11069422801 . It os not producing heat. Will randomly work but for the most part not heating. I have replaced the heating element the thermal cut out , high limit...
These timers are crappy but easy to take apart. The leaf switches inside there get a burr on it and no heat; basically like filing points on a car. Smooth up the contacts put her back and see is what I would do.
Sep 29, 2012 | Dryers
[ msikbd2k.sys ] I lost this driver
im not sure what that driver belongs to but to elimate any mistakes and elimate alot of searchin download driver checker it will automaticaly find and install the latest and most compatible driver and since the driver is lost you dont want to take any chances since u cant even reinstall old driver so download the program ENJOY
Sep 03, 2010 | Microsoft Windows XP Professional
PLEASE HELP.....cant not get Batizime pool to heat up.
something is wrong with the voltage it should be 240 when you test the heater terminals, i think the heater relay isnt making a good contact. but i would check for 240 at the main panel and chase the wiring to find the voltage drop.
Apr 02, 2010 | Hayward Comfort Zone Electric Spa Heater...
No heat but already replaced heating elimate
Check the thermal cuttoff. It is located on the element. If it does not have continuity, replace it. Also replace the Hi-limit thermostat, also located on the element, and the operating thermostat, located on the exhaust. These two should cut off the heat before the thermal cutoff blows.
Nov 25, 2009 | Dryers
I have an Amana Gas Dryer Model # ALG643raw
Sounds like the flame detector sensor may have failed, but you really need a multimeter to test the components in the circuit to make sure you replace the right partt
Aug 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer model 869-801-00 serial# m93688044 stock# 69801, 1989 dryer runs but gets no heat. replaced power cord. heating elimate was tested told to be ok. So what else could it be?
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jul 19, 2009 | Dryers
The heater
replace the thermostat it seems to be stuck
Nov 22, 2008 | 1998 Chrysler Sebring
2000 nissan quest over heating
you have air trapped in the system.
Go to this site for help
http://autos.groups.yahoo.com/group/villagerquest/
Sep 29, 2008 | 2000 Nissan Quest
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
