Question about HP OfficeJet 7410 All-In-One InkJet Printer
Hp officejet 7410 fax failure
Whenever I try to send a fax, the document feeder starts, then it goes "WHIIIIZZZZZZ!" and I get a scanner failure message telling me to power off and restart. What can I do to rectify this problem?
  • 10 more comments
  • bobwilkie Feb 29, 2008
    I get the same problem. I place a document in the feeder and try to scan it or fax it and I get the same WHIZZING sound and a failure along with my paper being stuck in the feeder partially! I have not yet found an answer to the problem.
  • Anonymous Mar 21, 2008
    Feed half way than make noise and sanner failure message.
  • BHogan Apr 16, 2008
    I have the same problem. I can print, make copies, and receive faxes just fine. If I try to scan or send a fax I get the same Whhhizzzz Sound and the scanner failure error message. How much does replacing scanner motor cost?
  • slavingaway May 08, 2008
    My symptoms are the same as the other posters; I can copy (B&W or color) or fax as long as I use the flat bed, but when I use the document feeder, I get the loud noise after 1/3 of the page goes in and the "Scanner Failure" message appears.  Since the copy function works, I don't see how this can be a true "scanner" problem.  I've tried all the "Solutions" on HP's web site. I also did a chat session with an HP "tech??" who only wanted to sell me a new unit.  Thanks.
  • nomore HP May 27, 2008
    When ever I try to fax anything I also get a Wissssing sound and the fax will not go thru and then a print out will read that there was a power failure.Also a explanation icon will appear on the screen.I made contact with a HP rep.and he tried to sell me a newer model.He said this one is no longer manufactured.Then for $39.00 he offered to tell me what the problem is. This machine is only two years old and was seldom used.
    Un happy H/P customer
  • mgmnyc Jun 05, 2008
    My problem is exactly the same as the one described by phtismedic1:
    "Whenever I try to send a fax, the document feeder starts, then it goes
    off and restart. What can I do to rectify this problem?"
    We tried following our instruction manual on cleaning the document
    feeder. It didn't help. HP tells me they can't fix it and I
    need to buy a new printer. Our printer is only a couple of years
    old, and it's good, and I'm not ready to trash it yet.
  • Carolstuff Aug 15, 2008
    The very same thing!That is exactly what mine is doing,someone please help,I am going crazy trying to figure it out!
  • GRT21 Mar 30, 2009
    fax or scan attempt then "whizzzzzz" and power failuer notice
  • barbks Mar 31, 2009
    hp 7410 - with vista--I try to scan and print a document and then the scanner says I have an error-turn on then off before I can print another document.
  • fred lane Apr 05, 2009
    I get the gear noise and I tried relocating scanner on belt but that did not solve problem. then I read the The solution from tech in Dallas about needing new scanner motor where can i get a new motor and is it worth while changing. are the morors all the same I see this type HP oFFICE JET in yard sales all over maybe not exact number series but similar.
    i don't want to have to buy a new printer. and if there are any special tricks to changing motor please share. thanks I M not a tech
  • Anonymous May 19, 2009
    The solution by jcloyd on June 19, 2008 worked for me. It was very simple--took me about 10 minutes. The most difficult part was the trip to hardware store to buy the T8 screwdriver.
  • mziegler May 11, 2010
    jcloyd
    Please clarify how to remove the fromt control panel to access the two hidden screws.
Had the same problem as everyone else here - would copy fine but faxing or scanning resulted in the "whizzzzzz" sound (with or without the sheet feeder) and a mandatory reboot.
I followed the suggestion of moving the scanner head to a different part of the drive belt and it works fine now (at least until that part of the belt wears down!). Here was the procedure - it took about 10 minutes.
  1. Remove all T8 screws from the top of the scanner bed - there are two hidden on the left side under the removable flap and two more hidden behind the front control panel cover, which just snaps off.
  2. There is a bundle of wires that prevents the entire top from lifting completely off, so lift it high enough to clear the plastic parts, then rotate it 180 degrees around and set it on something to support it.
  3. Lift the scanner head until it comes off the guide rod and disengages from the drive belt.
  4. Move the scanner head to the other end of the bed and reingage it onto the belt and guide rod - this is a little tricky to get the belt to pop back into the scanner head, but I got it to go by holding the belt firmly on either side of the head and squeezing both together.
  5. Replace top and all screws, pop control panel cover back into place.
  6. Rejoice in saving yourself lots of $$ and preventing more junk from entering the landfill!
Posted on Jun 19, 2008
The whizzzzz is caused by the scanner belt slipping due to ware on the teeth ,however only the thrust side/end gets worn ,the ldle side can be moved by 180 deg to put the unused teeth it in the position that will make the printer fully operational until they are worn, HP do not have any spareparts and this belt would cost around $15 if you could get one it is also used in ofer printers
Posted on May 01, 2008
The front panel just snaps in and off
Posted on Apr 05, 2009
I tried solution #4 and don't think I achieved what was recommended, but I did end up rearranging the gear wheels. The wheel in the front seemed to be a bit more worn. Remembering how to put it all back together "PRICELESS!" I am happy to say that my doc feeder is operating again. It seems a little slow on the up take but then goes right on through.
Posted on Jun 25, 2008
  • Sandi Norton Jun 25, 2008
    I noticed that #4 that I referred to became #5 after I posted.
    I'm learning about this web site. After I rated #4 aka #5, it became #4 again.
Hp 7410 gets 232 error
Posted on Apr 09, 2008
Same thing for me. Maybe it's the feeder motor but it's not the scanner motor. The machine copies, scans fine without using feeder. I cleaned all rollers and mechanisms. the paper appers to feed fine untill it just reaches the glass then the old whizzzz sound.
Really need help on this one, anyone. Thanks
Posted on Apr 08, 2008
This is a scanner moter error need new one im a printer tech in dallas
Posted on Mar 16, 2008
  • 152 Answers
Scanner pickup roller need service or replace
Posted on Feb 29, 2008
I want to fax a document
Hi
To send a fax from your hp officejet
Follow these steps to send a fax from your HP OfficeJet.
1 Load your original.
Note: You must use the automatic document feeder (ADF) for multi-page
faxes.
2 Enter the fax number using the keypad.
3 Press Start Fax, Black or Start Fax, Color.
Oct 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I want fax a document
Hi
faxes.
pls vote me i help you
Where is the document feeder cover?
The doc. feeder cover is at the very top of your machine, it covers the rollers that pull in a document when you are faxing or copying.
Aug 27, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 08, 2009 | Office Equipment & Supplies
HP 5030 do not send fax properly
Open the document feeder and clean the scanner glass.
Dec 30, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
WON'T SEND FAX FROM FEEDER.
u can try the following steps >
unplug the power cord from the back of the unit [without turning off the unit ] > press and hold ok and cancel key together > while holding these keys down plug in the power cord back into the unit . do not release the keys > wait for a few seconds it will make certain noises an wud turn off automatically .
turn on the printer again it will go into allignment phase > let it finish.
after its done > try to make a copy from the feeder .
Note - In case [ok and cancel key ] combination doesnot work < u can try # and 6 key combo as well with the same procedure.
THANKS
Mac
Mar 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
SCANNER FAILURE
first you try with changing the usb cable and see. bye
Sep 28, 2007 | HP Officejet 4215v All-in-One Printer
HP OfficeJet 7410 All-In-One InkJet Printer Logo
995 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
