Use the allen wrench from the on board tool kit to remove the bolt behind the passenger seat pad, above your rear wheel. Pull the pad backwards to reveal 2 more bolts. Same allen wrench removes these two and the strap that secures the passenger pad. Pull the saddle back and you are done. Note that the bolt for the rear seat and the 2 for the saddle are not the same lengths when you go to put your cycle back together.
Key releases back seat latch, 2 screws under rear seat section
Lift the rear of the passenger seat's cushion to find the screw that secures the seat to the rear fender. Use a 5-mm Allen wrench to remove the screw.
Lift the rear of the passenger seat slightly and pull it away from the rider's seat.
Use the 5-mm Allen wrench to remove the screws from the rear of the rider's seat.
Lift the rear of the rider's seat upward slightly. Pull the seat back until the tabs on the front of the seat separate from the motorcycle's frame.
