Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Hello noggin can u help me my printer reads "media error" reinsert and i have no clue how to fix this!! help please
  • Soulvisitor
    Soulvisitor May 11, 2010
    Good call BFixed, I'd forgotten that the 440 had a card reader
  • Soulvisitor
    Media is refering to paper supply in the printer,ie not there or set to the wrong size compared to doc getting printed or getting jammed
    Scholar:
  • 104 Answers
Media error may also be that it thinks there is a flash media card in one of the slots on the front of the printer. If there is one present remove it.
Posted on Mar 07, 2008
X2600 printer has EC5 problem
The error indicates that there is a short in one if the cartridges. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Feb 07, 2012 | Lexmark X6150 All-In-One InkJet Printer
Cartridge Error .... help!? I've read all the other replies and it's not helped!
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge issues:
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 14, 2012 | Lexmark X4650 InkJet Printer
Message reads "cartridge short press power key"
The error indicates that one or both of the cartridges has a short circuit. Please follow the steps below to identify and fix the problem:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
I continue to get this error message on my HP A612.
first check the card to make sure it isn't write protected, if it isn't write protected, put the card into a camera and the camera should fix it
REF:
http://h10032.www1.hp.com/ctg/Manual/c00701123.pdf
Dec 25, 2009 | HP Photosmart A612 InkJet Printer
Printer says: media error, please reinsert
The most likely problem is that the Printer cannot read SDHC cards. Most cards over 2 Gig are called SDHC you can see on the card if it is infact one of those cards. if this is the case then just plug your camera into the computer and transfer the files that way then you can print them.
Jul 22, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer reads-"Printer error-see your documentation"... no clue as to what to do.
pull the plug and unplug it again..or load and unload your cartridge..,or change the cartridge you using...maybe the printer don't recognize the printhead..
May 12, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Brother mfc440cn help
    The printer thinks there is a flash media card inserted in one of the slots in the front of the printer, If there is one there remove it.
    Feb 29, 2008 | Brother MultiFunction Center MFC-440CN...
    Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
    166 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
