Question about HP LaserJet 1300 Printer
Ghosting The printer prints a ghost image of the printed image. I put a new toner in and it fixed it for a short period. But then it came back. What could it be?
  • 152 Answers
Problem in your fuser assy or pressor roller
Posted on Feb 29, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Printing ghost images (shawdowing)
You'll have to align the print cartridges. You should be able to do this with the software that was installed with your printer. Hope this helps.
May 08, 2009 | Minolta QMS 2200DL Laser Printer
HP Color Laserjet: ghost images, both black and color print jobs
Hi
sounds like either you fuser rollers need to be replaced or you need a new drum and cleaning blade, those 2 items will cause ghosting,
good luck
Jan 28, 2009 | HP LaserJet 2605DTN Color Printer
Printer light print
It sounds like the transfer wire/roller is the fault is the image like a ghost image ?
Jun 20, 2008 | Office Equipment & Supplies
Light print over entire page
clean the scan unit reflector
Mar 15, 2008 | HP LaserJet 2300d Printer
Minolta 2300DL ghosting
I just had the same problem with my 5430DL. It was a bad toner cartridge. The bad cartridge is at 73% full, and had not been a problem until recently. I had been troubleshooting and finally remembered that I had the old cartridge with toner still left. I swapped them out and no more ghosts. Swapped back and the ghosts came back. I have ordered another new toner cartridge and fully expect the problem to be resolved.
Jan 28, 2008 | Konica Minolta magicolor 2300DL Laser...
HP LaserJet 1300 Printer Logo
289 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
