Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Set played for 8 hrs. and shut off. Unplugged set and reconnected to power and set turned on. Set played for approx. 8 more hrs., shut off and can't get it to turn on again. home theater tv
    Genius:
  • 1,030 Answers
Intermitant problem idicates eather a component finally failing maybe overheating or a bad connection somewhere. IS the unit compltely dead now... NO green light flashing. or on no sounds clicks or smells. The rca ITC222 is known for shutdown. THe processor "sees" any problem at all it will shut it down for safety. You did what u first do that is unplug it and try again. Now the troubleshooting begins. Technicians have computer test equipment that can read errors from the processor. SO what is it doing now.
Posted on Feb 29, 2008
I have a Samsung HTC 550 home theatre system. It's set to region one and I've tried everything to make it region free to no avail. I want to watch a region 2 DVD. Can you help??
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote. (if your player is already set to region 2)
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Turn off power from remote.
11. Turn power back on with remote.
Player is now Region Free.
or
Turn on with remote control without disc.
When message "No disk" appears, press on the remote,
ENTER,
8,4,2,6,9
ENTER,
If hack work after the second ENTER player will power off automatic.
When power on again this was region free, I can confirm now read region 1, 2 and 4.
Sep 08, 2016 | Samsung HTC-550 DVD Home Theater System
55" model. Why does it play for a couple of hours, then shut down?
Sounds like you have a parental setting on the tv that is set to only allow 2 hrs then shuts down... try going into the menu and looking for parental settings or sleep settings... if that isn't it try spacing the tv away from the wall to allow circulation... it may be over heating... next would be to get a circuit checker for the wall plug and make sure the polarity is right at the power source... you would be surprised at how many homes are wired bkwards... usually sign of this problem is electronics in your home seem to burn out with in 6 months or sooner... tester has 3 to 4 lights on the bk of it and looks like a wall plug.. costs about 5 $
Jun 09, 2015 | Vizio Televison & Video
I have a noma outdoor mechanical 3-outlet lighting timer power stake with built-in photocell technology- 5 off settings but I lost the directions on how to set it. on the back it's marked SP-030 ...
the 2/4/6/8/ hrs settings work like the photo cell and start at dusk then remain on for the time set , ie 2/4/6/8 hrs then shut off
Dec 18, 2010 | Solar Home
I need to play videos in region 4
check internet for region free codes for your model, this is usually quite easy to set your system to not have any region restriction. so you can play dvd from all regions. I found this for your model.
1. Remove disc from tray.
2. Switch off player and unplug power cord.
3. Wait 30 seconds, then reconnect power cord.
4. Turn on player with remote. Wait for player to finish loading and display 'no disc'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
It might work. try at your own risk.
Dec 12, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
I have a Samsung 50" HDTV DLP TV that I purchased 10/12/2008. I turned the set on the other day and it would come on generate a normal picture then power itself off. I unplugged the set for a few hours...
Lamp could still be going out they only last for 5,000 hrs some 8,000 playing hours.
Check the Lamp Fan if it stops running when Lamp turns on set will turn OFF.
But if you have never replaced Lamp Problem will be the Lamp Mats Has them for $99.00
1-800-628-1118
Oct 23, 2010 | Samsung SP50L3HX 50" DLP TV
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
Problem
Going back some time ago, I believe that in this model of set, if there is a power supply failure, the sleep timer will show as activated.
I suggest calling the JVC service rep to find out details for this. I believe the power supply will have to be changed. Also, the tech will check the set to find the cause and service it as necessary.
Jerry G.
Oct 31, 2007 | JVC AV-27D302 27" TV
Turned off while watching, won't turn back on.
The TV is in "protect " mode,which means that it is shut down because of an internal fault condition. - unfortunately you need a technician to investigate the problem . THis is not a job for a hanyman. Sorry ..
Sep 13, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
