Question about Dryers
Roper RES7646JQ0 dryer will not heat. Have replaced the heating element, thermostat and fuse. drum turns, just not heating.
  • 156 Answers
Ck the power make sure you have 240 volts l1 to l2 and 120 volts common to l1 common to l2 if that ok chances are the timer bad
Posted on Feb 29, 2008
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Why roper dryer won't cool down??? Its getting way to hot....help! !!
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Apr 04, 2015 | Roper Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Roper dryer does not heat . replaced heating element and thermal fuse. what's wrong
No heat at all is usually the thermal fuse, the high limit thermostat, the heating element or you have a bad breaker at the box and are running on 1/2 phase (or 110 only).
With the power OFF and the dryer unplugged. Use and ohms meter (borrow one or pick up a cheap one for around $10-$15) & check the high limit thermostat (right hand side at the base of the housing for the heating element), take the wires off both terminals and check for continuity between the terminal (set the meter of ohms place the black lead on one terminal of the thermostat & the red lead on the other terminal, doesn't matter which, the needle should move, if it doesn't, replace the thermostat).
You can check all the thermostats, fuses, door switch & the heating element this way.
Feb 12, 2011 | Roper Dryers
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
I have replaced the heating element and cycle thermostat on my electric dryer but it still does not heat
have you checked the hi-limit switch on the heating element case, then the one shot thermal fuse in the line also
Nov 17, 2009 | Roper REX4634KQ Electric Dryer
Where is the heat element on this dryer? Dryer is not drying clothes. Dryer do spin but no heat. Changed fuses. Fan belt still intact.
Either on the back of the machine or on the floor under the drum.  If the lint trap is on the top it will be in the back of the unit, if the lint trap is in front, it will be under the drum.  Before you replace the element check the thermal cutoff which is on element.  If it is blown you will also need to replace the Hi limit thermostat also on the element.
Nov 07, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
130 people viewed this question
Top Dryers Experts
