Question about Seagate FreeAgent Go 120 GB USB 2.0 Hard Drive
Seagate freeagent 120 GB generating Event id 51
Problem occurs on XP home with USB2.0 but not on XP Pro with USB1.1. Got the runaround from Seagate India but the web reports indicate that this is uniquely a Seagate problem - big disappointment!
  • 1 more comment
  • MikeSS Feb 29, 2008
    On my XP Pro with USB1.1 I found that un-checking the power option for the USB ports in the Device manager cured the problem but did not cure the problem on XP Home with USB2.0.
    I noted on the web that changing the drive sleep setting via the drives tools has resolved the problem for some folks - have not tried as of this writing.
    This is an elusive but pervasive problem that Seagate hasn't owned up to yet but is reportedly primarily an issue with the Seagate FreeAgent product line. It is commonly attributed to the drive enclosure as opposed to the drive itself. Other manufacture's USB HDs are reported not to have the problem.
  • Bridieanna Mar 01, 2008
    Have the same problem, Seagate just stopped working, funnily enough it appears, at the same time. I have XP SP2, USB2.0. I had a windows update install (SP3) and the next day 1.3.2008 - NO SEAGATE. Up until then all was fine. I did system restore to the 25th Feb but to no avail. When I unplug power cord and replug, yellow light comes on, found hardware notice appears, then off goes the light and no sign of my "H drive" anymore. Shortcut I had established useless....... as expected. Buggar, wonder if I will be able to access seagate on another computer?? cheers June
  • Anonymous May 06, 2008
    disk not detected on win xp
I want to add my seagate free agent go 160 GB to window98 computer
Posted on Mar 21, 2008
Purchased my Seagate June 6, 2008 and have used it just a few times with my Win XP. I recently bought a new PC with Win 7 onboard (naturally). Now I want to transfer (copy) my music and photo files from...
Certainly, any files that you write using Windows XP will be able to be read with Windows 7.
I'm not familiar with the CEEDO program -- did the author update it for Windows 7 ?
Dec 26, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Where get free drivers for Seagate FreeAgent Go
I'm not sure what drivers you're looking for in particular, however, I've found the Seagate FreeAgent download page for you. I've clicked around and all of these downloads appear to be completely free.
These files should be completely safe for download as they are provided by Seagate but don't neglect to set a restore point on your system before downloading and installing. The files are .zip so they must be unzipped, your system should be able to do this without any additional software.
Also, be sure to register your equipment to get customer support should contacting them be necessary. Some of these will require you to contact the company in order to gain access to the download.
Check here:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Oct 16, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
We've a seagate FreeAgent Desk 1500GB drive that was working fine on XP and Vista, until today when it it is a read-only disk on vista computers. Works fine on XP. Any suggestions on how to get the write...
You must change the permissions for this drive.
Right click on the drive and select properties, then look at the security tab.
Use the edit button.
Then select your ID and check off all the boxes under permissions for users.
Nov 17, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent with server 2003 not working
Seems that Seagate did not release a version of software which could be used on a Windows Server 2003 platform. I checked their web site at the following link & didn't find any software supported on Windows Server 2003:
Sorry, but I can't help you with this one. Try contacting Seagat for this & see if they have a solution to your problem.
Jul 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
An error was detected on device \Device\Harddisk2
run dskchk /p /r
What's the pagesize file size?
Check proper seating of cabling as well.
More about chkdsk at:
https://technet.microsoft.com/en-us/library/bb491051.aspx
Aug 02, 2017 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
PARTITIONING MY FREEAGENT PRO 500GB
why dont you just make use of win98 bootable disc or smart installer to partition the stuff?
Feb 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
FREEAGENT 250 GB AND USB2 NOT CONNECTING
Most of the time if you get an event 51 error you will need to reinstall drivers associated with that device to fix it. I would delete the device from device manager, uninstall any software that you installed for it, then restart your computer and reinstall the software. I would do this for both the card and the drive. I would also run Windows update to see if it finds any other drivers that you do not have installed. If that does not work it is possible that the card and drive might not work properly together. The only other thing I can suggest trying is reinstalling windows
Nov 14, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent  Go 120 GB USB 2.0 Hard Drive Logo
293 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
