Question about Canon PIXMA iP1600 Printer
Larges spots of ink on paper
Sometimes....at least once a day....and sometimes continuously on each paper....i get large blotches of ink along the side or bottom of the paper. It is a mess...it gets on my desk, other papers, my clothes, not to mention ruins the paper itself. I have performed all the maintenance I can on it...from print head cleaning, to bottom plate cleaning. I even open it up and wipe down the different parts, where there is gobs of ink. This is getting to be more of a hassle.....and with the price of ink it seems like there is more on the inside and everywhere else than where it should be on my print job.
Any suggestions?
That used to happen to me as well. It turned out that when I left the paper standing in the tray, it would bend slightly at the end. I stopped leaving the paper in the tray in the afternoons and only putting it in when i needed to print and that seemed to solve the problem. A hassle I know but thats the cost of buying a photo printer to do office jobs.
Posted on Mar 26, 2008
Have a dark blotch on bottom right of screen. What is this? Transported in the rain and fear water got through carefully wrapped plastic. Help
It's possible the mirror has dome dust on it from jostling during the move. W dried water spot will do it too. The front screen will come off by removing the screws on the bezel. Be extremely careful cleaning the mirror.Any scratch by a cleaning cloth (never use paper) will permanently ruin it.
Nov 02, 2014 | Akai PT5492S 54" Rear Projection...
Hp 3210 not printing magenta and leaving large quantities of magenta ink in printer blobs on right side of paper
defective cartridge; make sure you buy ANY cartridge from a REPUTABLE, not cheap, cartridge company.
Dec 24, 2012 | HP Photosmart 3210 Printer
Both the the left and right have large color blobs, more intence at times, shows more on blk/white
There is a degaussing resistor that activates when tv is first turned on and purifies the screen so there is no color contamination, sometimes it will become defective or develope bad connections on the circuit board. The part looks like a box "black/green" and is located near the power cord. If it has stopped working it would explain the color blotches. To fix it! the part needs to be replaced or resolded back on the board and a degaussing coil used to give it the once over, tv tech carries one just for that purpose. The other possibility is if speakers are to close to the viewing screen the magnet will leave blotches and must be degaussed to correct it.
Feb 07, 2011 | Philips Televison & Video
Pavilion Laptop Screen Problem
It sounds like your screen was man-handled. You will need to replace the screen. You can sometimes buy them used online or you can get a new one from HP. Sorry for the inconvenience.
-Paul
Jul 12, 2010 | HP Pavilion dv6000z Notebook
Paper jams w/ all types of paper, Ink blotches...
If you're getting spots on the prints, run the Remove Ink Smears routine in the maintenance. It will clear the ink from the preheater. User packing tape to pull dust off of pick rollers. It's easy to unclip the unit and roll it on a piece of tape to remove dust.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Large black ink tank is not being used by the printer.
The little cartridges are pigment for photo printing. The Large black cart is ink for plain paper (usually text) printing. If you select a photo paper in the print setup menu, you will use very little of the ink.
To check the function of the large cart print out a test sheet from the printer maintenance menu. You may need to run a head cleaning to get all the nozzles to work.
May 11, 2009 | Canon i860 InkJet Photo Printer
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Dec 28, 2008 | Genius G-Pen F610 (31100050100)
Keys are striking the paper but no black ink is printing on paper
If tou put in a two part form and it types on the second form the ribbon is either empty of not lifting up. If it isn't lifting up there is a large black gear on the rt. side of the printer, wiggle it back and forth they sometimes jam tooth for tooth.
DickyO
Dec 19, 2008 | Lexmark Wheelwriter 6 Series II Typewriter
Getting spots on photos
I pulled out the cartridge that was causing the spots, dabbed at the small pool of ink that collected with a very soft paper towel, re-cleaned the print heads and that seemed to solve it...
Jul 11, 2008 | Epson Stylus 1400 InkJet Photo Printer
Canon MP830 - extreme ink useage
According to a service manual for a similar Canon printer, the grayscale printing should only use the Pigment Black ink PGI-5BK.
On fast it is 300x300dpi with 1 pass, standard is 600x600dpi with 1 pass and high is 600x600 with 4 passes.
On plain paper in colour it is meant to still only use the C/M/Y and again the big pigment black ink PGI-5BK, it only uses the smaller black ink once you set it to use a photo type paper in the printing settings.
Jan 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
204 people viewed this question
old marine
old marine
