Question about Vev Vigano Kontessa Inox 6-Cup Espresso Machine
The coffee is never strong enough
I've tried several times, even using different kinds of coffee, and it just never seems strong enough.  Am i not using enough coffee/too much water?  Any one have instructions on how to use this item?
Be sure to use a very fine grind of a true Italian Roast espresso bean, and don't be afraid to tamp or pack the coffee a bit. Also, you don't want to overheat the pot...a low flame (or setting on your electric stove) will work best.
Posted on Apr 08, 2008
Coffee machine steam wand pressure issue
Good question. I have been surprised before today after checking the manual for various gadgets. There are thousands of manuals online which can be searched for if it is missing. We have a bench top water filter fitted. When you have one of those, the difference is so noticeable that you will only want drinking water from there
Feb 28, 2014 | Coffee Makers & Espresso Machines
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
I have a Saeco Spidem Villa. Iâ??ve been
I dont understand what exactly happen when you try to make coffee? Is the coffee comes out or no?
Apr 20, 2017 | Saeco Spidem Villa
We are having a problem with our bun coffee maker. we have used several different coffee's to rule out that the problem is not the coffee. However it doesnt seem like the problem could be the coffee maker...
What brand of filter ae you using?
Some filters will filter too much and others not enough.
with 1.5 to 2 Oz of coffee in the filter, it should take 4 to 5 minutes to complete a brew of one 64Oz decanter.
Jan 06, 2010 | Bunn VPS Coffee Maker
I having a sporadic knocking from the bottom of the reffer side
ProbabyTry to Change Rubber Base Groumet for Compressor motor and there is nothing with freon
Kindly inform me When Solved
Good Luck
Feb 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Coffee not strong enough
I had a problem like this with my first proper Gaggia. Cutting a long story short I found that the coffee I was using wasn't ground finely enough. The Illy stuff that comes in cans was ok, but pretty much everything else preground (incuding Lavazza!) was too coarse.
Sidestep the problem by getting yourslef a Rancilio Rocky grinder then you can adjust the grind in TINY increments for your perfect coffee moment...
Sep 24, 2008 | Rancilio Silvia Espresso Machine
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Feb 09, 2008 | Gaggia Titanium Espresso Machine
Weak Coffee
Yep, it's the one inherent flaw in the single serve machines - someone else decides what 'the perfect cup of coffee' tastes like.  Quite presumptuous, actually.
Solution I found to be acceptable:  Buy only the extra bold flavors (there's about 5 or 6 varieties) and brew using the small cup size button.  Yes, you only fill your mug about 3/4 of the way, but at least you get a decent cup of coffee.
The ONLY flavor I found to be strong enough when brewing with the large cup control button is DOUBLE BLACK DIAMOND...the rest is crap.
Dec 27, 2007 | Keurig B50 Coffee Maker
Vev Vigano Kontessa Inox 6-Cup Espresso Machine Logo
302 people viewed this question
Top Vev Vigano Coffee Makers & Espresso Machines Experts
ray gallant
Mister Danger
Are you a Vev Vigano Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
