Question about Clarion DXZ375MP CD Player
I do not have a manual to see how to setup the my Clarion DXZ375MP radio. Where can I get a manual?
Go to the clarion site(www.clarion.com) and put in the dxz375mp number in the search section and it will take you to that cd player and you can download the instruction manual and the installation manual on the upper right hand corner.
Posted on Nov 17, 2008
I have the manual for the Clarion NX501, but it does not tell HOW to set clock.
Page 51 of the manual, under General Setup Menu, is Clock.
Here is where you set time, AM/PM, or 12/24 hour clock,
Nov 02, 2015 | Clarion Car Audio & Video
Subwoofer istalation into a clarion DXZ375MP stereo
The DXZ375 has two sets of RCA outputs (1 red plug, 1 white plug) located on the back of the unit. The set with the white main wire is for a front amplifier, and the one with the black main wire is the rear. You want the black one.
I'm assuming you also have an amplifier for your subs and the necessary wiring. You will need to run a 12v+ from the battery to the amplifier, splice a power-on signal wire from the ACC Power wire on the stereo's wiring harness (red wire) as well as connect the amp to the stereo via the RCA outputs.
Mar 11, 2009 | Clarion DXZ375MP CD Player
Clarion DXZ785USB - Connecting Fused Lines
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Jan 29, 2009 | Clarion DXZ375MP CD Player
Need wiring diagam
ok , here is the owners manual if you need it , maybe programming instructions are in there .
http://www.clarion.com/us/en/MungoBlobs/547/503/DXZ375MP-ENG.pdf
ok here is the installation instructions straight from clarion .
http://www.clarion.com/us/en/MungoBlobs/777/794/DXZ375MP-INST.pdf
and if you might need your vehicle schematics you might look here .
http://www.the12volt.com/
Johnny
Jan 14, 2009 | Clarion DXZ375MP CD Player
Radio display light
To get the back light on you need to hook up the illumination wire to the ignition acc wire
Jan 10, 2009 | Clarion DXZ375MP CD Player
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Aug 25, 2008 | Clarion DXZ375MP CD Player
Just installed my Clarion DXZ375MP and no sound - error message AMP_GRD
Charisse,
Check your speaker output wires - if they are shorted together that will cause the head unit's internal amp to go into a protection mode like that.
Mar 06, 2008 | Clarion DRX6375
Connecting a wire
leave it hanging u dont need to hanve it dim with dash dims dont use it
Jan 21, 2008 | Clarion DXZ375MP CD Player
How to install the wires for a Clarion DXZ375MP
there shold be a "hot at all times" wire in the dash where the old deck came out of, that is what you want to wire them too.
Nov 28, 2007 | Clarion DXZ375MP CD Player
Clarion DXZ375MP CD Player Logo
378 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
