Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Buttons lit up, washer not going
Our buttons all light up... however the washer will not start at all. any suggestions?
  • 3 more comments
  • Anonymous Mar 08, 2008
    The machine has no clothes in it and the water had been shut off all day to fix a shower. When the water was turned back on I went to put in a load and the washing machine was full of water and we are unable to drain the water out. The lights are all on and it lets me choose drain and spin but no motor action. It just sits there. Thanks if you can help!
  • rleec Mar 28, 2008
    I have the same exact problem as described. Following the instructions in the troubleshooting section of the manual does not result in an error code.
    Was anyone else able to resolve this problem? If so, your assistance would be appreciated!
    Thanks in advance,
    Rick
  • tolmeth Apr 23, 2008
    Washer will not start. Advice in manual troubleshooting guide do not help.
    Jerry
  • Anonymous Apr 25, 2008
    does not start
  • dranne May 23, 2008
    Our buttons - with the exception of the door lock button ALL light up. Won't allow me to "reset it" at all - Just keeps blinking. I've replaced the door lock. HELP?!
  • 96 Answers
If nothing works, no water and no motor action, then it sounds like a door switch or door lock problem. Check to make sure door is properly shut and switch is operating.
Posted on Feb 29, 2008
HOW CAN I DO A LID LOCK TEST
Place unit in diagnostic turn knob till rinse and spin are lit press the start button lights should go out press start again the lid should lock light on press again unlock and off
Jan 12, 2015 | Amana NTW4501XQ 3.4 cu. ft. top load...
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
"Control Locked" lamp is lit on the washer. Tried
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer beeps at the end of each cycle,must be advanced manually
Hi Steve just read your posting.Now when it starts to beep a series of lights will light up.Starting from left to right they are numbered 1st on the left=128 next is=64 next is=32 next is =16 next is= 8 next is = 4 next is = 2 next is = 1. So the lights are numbered from left to right 128--64--32--16-- 8-- 4--2--1. now with this information look at the lights that are lit add up the value of the lit lights and reply back and i will look in my service manual and tell you what part or parts are faulty. hope this helps.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
"Control Locked" light is lit. Washer won't start now.
Hi
Thanks for using FixYa. Press and Hold the "End Of Cycle" button so that it resets itself. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG WM2487H*M Drum light stays lit after each load is completed
Solution. Unplug the machine. Hold the power button for 10 seconds. Plug back in. Push the power button and the washer should turn on. Walk away leaving the machine on. When I did this, I came back to find the drum light off and machine would start on command now. Good luck.
Feb 12, 2009 | LG WM2487HA Washer
Whirlpool duet sport washer 3.6 WFW8410SW cycle will not start
set it to spin dran cycle and select no spin and push the rinse hold button 4 times it should read c00 on the dis play and go thew to c08 it will lock the door frist and then go thew all the cycles it will flash on a c# that has trouble
Nov 29, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
WASHER WON'T START
possible door latch or even the strike on door itself may be broke
Sep 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start - lights up but won't stay on
have you tried pushing the button twice? That's what I have to do.
Jun 05, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
