Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
No more I turned my computer off it will not power on. checked power cord and power outlet--is there a battery or something to replace?
  • Anonymous Mar 16, 2014
    pc has no power; checked cords and outlets. Heard it could be dead battery on motherboard. If so is this hard to replace?
    Problem Solver:
  • 11 Answers
If there is a reset button on the computer or power supply try pressing it
Posted on Mar 07, 2009
    Genius:
  • 1,019 Answers
Im assuming this is a desktop computer.
I ask this, because sometimes people post in the wrong categorys.
If your getting no power, Then the first steps, are as you,ve already done, checked the plugs main fuse. Should be rated 3-5 Amp.
The next suspect item, would be your computers PSU ( power supply Unit ) This can only really be checked with a multi-meter, if you take the side/top panel off. ( whichever Applies ) Towercase Or desktop.
You have an internal Power supply unit. This provides power to Motherboard, and internal hardware Devices. Hard-Drive CD Rom And any other internal devices. You,ll see a Square Box to the rear of The Computer, with several cables coming out from it. The Majority will Have 1 Red @ 5volt 2 Blacks Earth or ground And 1 yellow Cable @ 12 volts.
There may be an internal quick blow fuse in the PSU Itself.
To attempt to remedy your issue, i,d suggest to remove ( unpowered switched Off ) the 4 Pin Connector To the Hard-drive And the CD/DVD rom. These 4 pin Plastic Plugs are refered to As molex Connectors. simply pull the plugs, towards the rear of the Computer. HD/DVD Drives Only. Then try to power On Computer. this will eliminate, a possible hard-drive failure or seizure, and also allow the PSU extra power for booting up the Computer.
Other probabilitys are broken or faulty, power/On case switch, but quite rare.
If you follow these steps, and get some form of life from the Computer. Please let me know, and i will guide you further.
Mike @ compurepair.
Posted on Feb 29, 2008
Have acer one message says to plug into ac adapter
Check the AC adapter and power cord. It sounds as if either one end of the cord near the transformer box is loose, or the end that plugs into the computer is loose/not connecting properly.
Failing that, make sure the wall socket you have the cord plugged into has power (try plugging something else into it). If everything I mentioned checks out, there could be something wrong with your battery.
Mar 23, 2012 | Acer Aspire One D255 Netbook
Inspiron 2305 power cord doesn't turn the desktop on
After connecting the AC adapter to a wall outlet and to the computer press the power button the right side of the inspiron. The button itself should then lite up white if the power adapter is good. If not, check the power outlet you are using. Plug in something else and see if it works on this wall outlet. Some outlets are connected to a wall switch. If its still a nogo you may need to replace the AC adapter.
Sep 18, 2011 | Dell Inspiron One 2305 Desktop Computer...
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
Battery doesn't appear to be charging.
There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
Mar 19, 2011 | Dell Studio 17 Laptop
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
My computer won't turn on or charge.
You need to diagnose the problem.
>First try to take the battery out of the computer and just use the charger to make computer run.
>If it turns on it means that the battery is what's causing the problem.
>But, if computer cannot run using the charger/AC Adapter then it means that we have a problem with the charger.
By doing this diagnostics you know which part to replace.
Sep 30, 2010 | Toshiba Satellite A85-S107 Notebook
How and where do I replace a fuse on A tom tom one car power cord
Ther is a small batery looks like large watch battery or computer battery inside unit.
sumtimes thay are soldiderd in place.
you should change it with new one.
this will fix your problem.
Jan 10, 2009 | Tomtom ONE GPS Receiver
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
