Question about Moultrie MFH-DGS-100 Digital Camera
Lost Manual Hi,How to set for motion only.How to turn flash off.
    Problem Solver:
  • 5 Answers
You can call 1 800 653 3334 and they will send you a manual and tell you a website where you can print one
Posted on Apr 21, 2008
  • ozz50842 Apr 21, 2008
    the flash has 3 settings off on and auto auto will came on at night
Just installed a motion activated light (model 021746). The light will not turn off; there is no switch.
in the installation notes , it probably reads to this effect
to run the light all the time --switch of power supply and switch on
to run a light sensor - turn the power off , back on back off back on
one action changes the internal program to leaving the light on , the other activates the sensor mode
the switch is the light switch that controls power to the unit
Oct 26, 2016 | Home Security
I have lost the manual for this product and would like to know how to set it up, at this time it stays on when the light switch is on.
If you turn the switch off and on real quick the light should stay on. If you turn the light off for about 5 seconds and then turn it one, then it should sense something that moves and is warm depending on the sensitivity switch setting.
May 10, 2015 | Hampton Bay Outdoor Lighting. Alexandria...
Samsung un60es6100 won't turn on just red flashing led
That is probably an overload indication. The lamp may need replacing or the optical engine may be malfunctioning. Either way it needs careful examination. Read through the owners manual on lamp replacement procedures, etc. and check the troubleshooting section in the manual. If you have lost the manual you can download it from online search. Also, count the number of flashes when set turned on that is a trouble code for the set.
Aug 15, 2014 | Televison & Video
Don't know how to turn flash off my Coolpix iso 1600
press the flash symbol to open the flash menu, now using same selection ring of buttons navigate to the setting you require, press "OK" to confirm.
you can download a replacement manual file here (PDF), you can save it to your computer/laptop.
Dec 17, 2013 | Nikon COOLPIX S200 Digital Camera
Why does the flash come on when there seems to be enough light
I am assuming that you are in manual mode. It's on board computer has decided that to prevent camera shake or motion blur that the flash was needed. Now there are things you can do if you don't want the flash to fire. If you use one of the manual modes and set your ISO to a high ISO(800ish) and make sure your f-stop is set for the lowest number your lens will accept.
Play around and see what works for you. Chris
Jul 03, 2011 | Nikon D40x Digital Camera
When i flip the switch on the light stays all night it doesnt turn off it was working fine i dont know what happen an i lost manual so can u please help me
Clean the light motion sesor plate under the light bulb.It dirty and it cover with dirts and moister probally that,why it on all the times.
Oct 16, 2010 | Heath Zenith 270 Degree Replacement Motion...
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Forgot password
If this is a desktop computer, look for the bios flashing button on the motherboard or just remove the CMOS battery from the motherboard ( possibly located below the RAM slots ) that is like a coin. and place the battery back after 1/2 minuets. It will clean the BIOS password.
Apr 18, 2009 | Motion Computing MOTION LE1600 Notebook
2006 flhri road king alarm problem
Hi Cammy, I hope you are following the instructions in the Owners Manual?  The steps are as follows: 1. Turn IGN on. 2. Press and hold keyfob until the turn signals flash 3 times 3. Turn IGN off 4. Press and hold keyfob until turn signals flash 3 times again.  Red seurity light will be flashing on and off.  Alarm will be set but motion detection will be deactivated.
Feb 23, 2009 | 2006 Harley Davidson FLHRI Road King
3100Z Focus Problems
re you sure the out of focus condition is due to the actually focus or do to motion blur? I think the 3100Z in auto and flash on will set the shutter speed fairly low like 1/30th of a second for wide angle and 1/90th for full telephoto. This may not be fast enough to avoid motion blur. I would suggest using manual mode and shutter priority and set the shutter speed to 1/100th of a second. This won't effect the flash output but will reduce the amount of ambient light being captured which could cause long range shots to become darker in the distance. Name of the game, don't be afraid to take it off auto mode and experiment with manual setting.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Moultrie MFH-DGS-100 Digital Camera Logo
63 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
