Hotpoint Front Loader Washing Machine
I have a Hotpoint Aquarius WM63 (i think) which won't turn on. I think the problem is with the door lock, is this easy to fix?
  • 41 Answers
My neihbors Maytag had a bad "wax motor" on the door. It's the locking mechanism. When it went bad it also damaged the control board which I was able to repair luckily. Total cost was less than $50. I don't charge labor..haha. If it's just the lock I'd say <$200. If the control board is bad I'd say >$500.
Posted on Feb 29, 2008
Hotpoint Aquirius 1100 - WM63 Hi, A leak has sprung from my washing machine and being fairly capable I've already had the sump off cleaned that out and re- attached it and checked the door seal for...
Hotpoint Aquirius 1100 - WM63 leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How to take bearing out of aquarius model wm63
The information for dismantling and rebuilding a Hotpoint WM washing machine is all in the workshop manual including wiring connections
Mar 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wm63
the noise is the pump trying to turn take it off, and check it for something caught in it a coin or some object bye eire
Dec 03, 2007 | Hotpoint Aquarius WD63 Front Load...
The heating element for this paticular model is located on the front casing of the drum.. you have to remove the front panel complet with the door and you will see it at the bottom behind a black protective cover.
Nov 27, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius model wm62
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Nov 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius 1100 WM63
some times when there is no motor action people think the machine has stuck try a set of brushes you must diconnect from the electrical mains first if unsure call an expert you can not put a price on safety
Oct 08, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
207 people viewed this question
Top Washing Machines Experts
