Question about Whirlpool MH2175XS Microwave Oven
Fan When you are cooking with the microwave the fan does not turn on. It also will not come on by manually turning it in. When you press the fan button it comes up "slices" on the display....any thoughts. Thanks
  • Whirlpool Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Posted on Mar 02, 2008
  • shopperchick Jan 06, 2011
    It worked! Thanks for saving me $300 to replace!!!
I got a Kenmore microwave hood combination model number 721.80032 is it a hood fan to and how do i just turn on the hood fan
The model number 721.80032 is a partial model number; it indicates the build series. I found the Kenmore microwave, 721.80032700. The final 3 digits indicate the panel color and similar details.
Assuming the microwave was installed properly, it should work as a hood fan. Press the touch pad with the fan icon (underneath it says Hi/Low/Off) to get the desired fan speed. The icon is on the lower left of the control panel; it's below the Cook Time button and to the left of the Light button.
The manual for the 721.80032700 is available here: https://www.searspartsdirect.com/partsdirect/user-manuals/72180032700-kenmore-parts-manual?manualIndex=0 . The direct link to the Owner's Manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0710653.pdf . See pages 9 and 14 for using the exhaust fan.
I hope this helps.
Dec 25, 2017 | Kenmore Microwave Ovens
Cannot turn microwave off. Help
Only happens when cooking a big pot under the microwave? Hosing thermal fuse / thermostat kicks in to cool the microwave. Is the micro. Installed proper height above the range? Are you using the fan when cooking on the range?
Apr 30, 2016 | LG Microwave Ovens
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
My fan kicked on by itself and won't shut off
The over the range microwave hood has a heat sensor in it. If it senses hot temperatures from cooking below it will turn the fan on. The fan will turn off once it cools down, this is to protect the microwave controls from damage.
May 08, 2010 | Magic Chef CMV1100 Microwave Oven
Will an over the range microwave exhaust fan start automatically If the range cook top gets too hot.
NOT THAT I'M AWARE OF . YOUR UNIT SHOULD HAVE A SWITCH TO TURN ON AND MUST BE TURNED ON MANUALLY
Oct 12, 2009 | KitchenAid KHHS179L Convection/Microwave...
When you press start I can hear the internal fan, but the inside table does not turn and there is no cooking taking place. What should I check first and what could be the problem?
This looks that the motor is not being functional, for that you have to look for the fuse if one. or else check the circuit if any wire is disconnected or burnt out accordingly you can decide what needs to be done.
May 05, 2009 | Sharp R-1874 Convection/Microwave Oven
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
The fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Dec 14, 2008 | Goldstar MV-1615 Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 16, 2008 | GE JVM1870 Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Whirlpool MH2175XS Microwave Oven Logo
253 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
