Question about iLO DVDR05 DVD Recorder
ILO DVDR05 recorded DVD's freeze
Last year I backed up most of my old VHS tapes using ILO DVDR05. Once I got the procedure down pat, recording was no problem including finalization. Recently, I've tried to play the disc's on a different player and the movie freezes. Sometimes right away, sometimes toward the end of the movie. I then tried to play the movie on the Ilo unit and it still freezes. What's up? They played after being recorded but now they freeze? Is it the players or the recording? Help
  • dryone Feb 29, 2008
    I'll record a sports program that may last over 2hrs & it can just freeze @ any moment when I playback. Have not been able to figure out the problem,these dvds are rewritables & I should be able to record at least 1000x.
  • seraphim May 11, 2010
    No I haven't solved the problem. I would be very happy to buy the "Premium" assistance plan if I knew I would get a decent answer. I fear I'll be told it's shot and to buy another one. If you are willing to give me a workable solution, I'd pay for the plan AFTER the fact.
  • 979 Answers
Burn your DVDs at tow positions slower than what the system and discs say. It sounds as if there is a huge amount of error being introduced during the write process. Unfortunately, the old discs can only be recovered with an external program like Zero Assumption Recovery or the like....accordianman
Posted on Mar 17, 2008
Problems with iLO +R/RW DVD Recorder, DVDR05. Often says bad disc when trying to record and when trying to finalize. Often says bad disc of a recording made by the recorder.
I've had this happen with incombatible discs (only uses +R&+RW and is picky about what brands. I've successfully used Sony +R's and many brands of +RWs. I have two different models - A ZU and MU. One asks to finalize the RW's and the other doesn't.?? If I have the choice, I don't, then I can add to it later. Does it say bad disc to discs NOT created by the ILO?
Oct 27, 2008 | iLO DVD Recorder DVDR05
ILO DVD Recorder/Player DVDR05
I'd take it back before you can't and get your money back. I bought two ILO's !one was a DVDR04 and the other was a DVDR05 and they didn't last even 6 mo. and all ILO has to say is pay us and it will work again but for how long, Until they want more money. Ithink they rig them to fail in the programing so they can charge for more programing.
Sep 03, 2008 | iLO DVD Recorder DVDR05
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
Ilo
I have the same problem when using the coax hookup. try using another input and see if that helps, I no longer use the tuner, just hook my tv up to the inputs and set the tv on what I want to record, same with vcr tapes etc.
Jun 07, 2008 | iLO DVD Recorder DVDR05
Dvd recorder
Following the instructions on hooking up the cables gave me fits. I finally just put the instructions away and winged it. Got it that way. Bypass your Ilo tuner. Hook the Comcast Cable (outs) up to the A/V input 1 of your ILO. Hook your tv combo A/V outputs, to the ILO A/V inputs. Select the Source and choose the cable source for cable and the combo source to tape from your VHS/dvd combo. Its a pain but you have to select Source everytime you turn the Ilo back on. You could hook your Cable to the ILO but would have to turn on ILO everytime to watch tv. Two remotes is a chore but you have to use tv remote for the volume anyway so it doesn't matter. Hope this helps.
Mar 30, 2008 | iLO DVDR05 DVD Recorder
Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
Mar 18, 2008 | iLO DVDR05 DVD Recorder
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Panasonic recorded dvds? what's up?
http://service.us.panasonic.com/OperMan/findmanual.aspx?model=DMRES40V
Try the Manual. It has a finalizing section. This is the link above.. Pat
Aug 02, 2007 | Panasonic DMR-ES40V DVD-Video Recorder
iLO DVDR05 DVD Recorder Logo
137 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
