Advent 7104 when i am playing games it turns off i have watched the temp and it goes up to 84 degrees and then turns off the fan on the side is working because i can see it is this problem only happens when playing games when laptop is idle the temp is 60 degrees how can i check the heatsink fan to see if that is the problem hope you can help please thank you
    Novelist:
  • 113 Answers
For laptop computers there is little you can do internally - for example, you cannot replace the cpu heatsink/fan with any other one than the same model. However I've had pretty good results by getting a nice laptop stand that has one or two large fans built into the stand. This dissipates the heat generated by the laptop much more effectively than sitting on a flat desk or other surface, and with luck, it may allow you to game on without shutting down.
Also, you can turn off some of the game effects - which requires less processing, thus less heat is generated.
Posted on Feb 29, 2008
Core temp
The fan could be partially faulty and cannot spin fast enough.
You can also purchase a fan assisted cooling pad and place the laptop on this cooling pad.
Apr 06, 2013 | HP Pavilion dv6-1030us Notebook
Which buttons do i press to turn on the internet on, on a dvent net book
Hi
do you mean to enable the wireless switch so that you can use the internet
as you have not told us which model you have i can not tell you where the switch is
please try some of these options if your model is mentioned
Advent 7086 ---- Button next to the power button
Advent 7096 ---- Button next to the power button
Advent 7100 ---- Fn / F2
Advent 7104 ---- Fn / F2
Advent 7201 ---- wireless key top right and then Fn / F2
Advent 8117 ---- small slide switch on the front of laptop
hope this has helped you
many thanks
Aug 17, 2011 | Advent Netbook
Thermostat temp guage goes to 220 degrees
220 degrees is normal operaing temperature for your car. The thermostat does not open until 195 degrees and the fans don't come on until 126 to 128 degrees. If it gets over 129 degrees and the fans have not turned on then the cooling fan system is the cause of the problem. (cooling fan, cooling fan temp switch, cooling fan relay, etc.)
Dec 05, 2010 | 1994 Buick Century
Hi my advent laptop says its wireless enabled but when i have tried to set it uo with my wireless router it says i have no connection i have been told by my internet provider to get intouch with advent but...
You may have turn the wireless radio on first before you can connect to the internet.
Look down the sides of the laptop for a small slide switch and push it, an LED light should come on.
If you can't find a switch then hold down Fn and hit the F2 key.
Regards.
Nov 17, 2009 | Advent Netbook
Cooling fans will not operate
IF YOU HAVE A SCANNER, WATCH THE COOLANT TEMP. LET THE ENGINE RUN UNTIL THE FANS COME ON. IF THEY DO. THE SYSTEM IS DESIGNED TO COME ON AT AROUND 228 DEGREES.
Jul 10, 2009 | 2004 Pontiac Grand Am
Advent laptop 7619 keeps shutting down
yes clean the fan with compressed air, and check bios and see if it is set to shut down at 105 degrees temp if it is move it up to 130%.
Jun 22, 2009 | Advent Netbook
Overheats in traffic only to 21 degrees
Go the Cheaper Route First and Go back to the Parts store and ask for a Cooler Thermostat. Try that and let me know what you have got.
Jan 10, 2009 | 2003 Pontiac Grand Prix
Trouble with newly installed thermostat
did you program your own temps, if not i believe this is part of default program!
Jun 30, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dismantling advent 7104
i have the same problem, anybody?
Mar 01, 2008 | Recoton Advent Advent Q2035A 20" TV
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
